    changing the content of plugin-folder
    10 Posts 0 Posters 794 Views
      On 26/06/2006 at 13:27, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Platform:    Mac  ;
      Dear Developers,
      I have a quite simple thing: To get a simple versioning of my first testprograms as a Plugin-Developer, i make some copies of the plugin-folder of my cinema4D-Installation.
      If I want to "roll-back", I just :
      1. Quit cinema
      2. take out the plugin-folder
      3. put-in an older version (i.e. the "original-version of the sdk"
      4. restart cinema.
      That should work, right?
      But if I put back the "original-version", I don´t get the sdk-plugins launched by cinema.
      BTW. Is it really necessary to restart cinema4d when re-compiling the plugIns?
      Thx,
      Jens
        On 26/06/2006 at 23:17, xxxxxxxx wrote:
        Sure ... You have to restart C4D ... ( as much as I know ) ...
        ZawMinTun
          On 26/06/2006 at 23:23, xxxxxxxx wrote:
          Yes, CINEMA 4D needs to be restarted. The best way is to start it from the development environment because then you can also set breakpoints and debug the code.
            On 26/06/2006 at 23:40, xxxxxxxx wrote:
            Yes, for C++ compiled plugins, you must restart Cinema 4D for the new code to be loaded into memory. Remember, they are static libraries - very much similar to those you compile into applications (zlib, for instance).
            I too wish there was a way around that.
              On 27/06/2006 at 00:41, xxxxxxxx wrote:
              however, you can change your code during runtime while debugging and also recompile changed parts during debugging.
                On 27/06/2006 at 13:33, xxxxxxxx wrote:
                Thank you!
                The other thing: What can be the reason: I put the original sdk back into the plugin-folder, launch cinema but then I don´t get the sdk-plugins?
                Jens
                  On 27/06/2006 at 13:56, xxxxxxxx wrote:
                  If you have two versions of the sdk plugins, they will conflict in Plugin IDs if they have not been changed. Each plugin requires a unique Plugin ID acquired here. The plugin IDs in use by the first sdk folder are the same as those in the copied sdk folder, causing them not to load.
                  I would not use the copies of the "cinema4dsdk" folder for writing plugins as you'll continuously run into this problem (except for maybe your own plugin's unique ID).
                    On 28/06/2006 at 05:18, xxxxxxxx wrote:
                    Robert,
                    If I take out the sdk-folder of the plugin-folder and replace it with another sdk-folder, they shouldn´t conflict, right?
                    But sometimes (I don´t know when) after such a change, the sdk-plugins are not recognized by cinema.
                    Jens
                      On 28/06/2006 at 07:48, xxxxxxxx wrote:
                      As long as you are quitting Cinema 4D before swapping folders and then restarting afterwards, it should find them.
                      Make sure that you are storing the 'swapped-out' sdk-folder in a folder external to Cinema 4D's "plugins" folder. I keep a folder called "plugins_backup" in the Cinema 4D install for this purpose.
                        On 28/06/2006 at 13:55, xxxxxxxx wrote:
                        Ok. You are right. It was my fault. The Problem was just that the sdk didn´t compile because of an error.
                        Swapping works fine as described.
                        Thank you,
                        Jens
