changing the content of plugin-folder
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 26/06/2006 at 13:27, xxxxxxxx wrote: User Information:
 Cinema 4D Version: 9.6
 Platform: Mac ;
 Language(s) : C++ ;---------
 Dear Developers,I have a quite simple thing: To get a simple versioning of my first testprograms as a Plugin-Developer, i make some copies of the plugin-folder of my cinema4D-Installation. If I want to "roll-back", I just : 1. Quit cinema
 2. take out the plugin-folder
 3. put-in an older version (i.e. the "original-version of the sdk"
 4. restart cinema.That should work, right? But if I put back the "original-version", I don´t get the sdk-plugins launched by cinema. BTW. Is it really necessary to restart cinema4d when re-compiling the plugIns? Thx,
 Jens
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 26/06/2006 at 23:17, xxxxxxxx wrote: Sure ... You have to restart C4D ... ( as much as I know ) ... Thanks
 ZawMinTun
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 26/06/2006 at 23:23, xxxxxxxx wrote: Yes, CINEMA 4D needs to be restarted. The best way is to start it from the development environment because then you can also set breakpoints and debug the code.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 26/06/2006 at 23:40, xxxxxxxx wrote: Yes, for C++ compiled plugins, you must restart Cinema 4D for the new code to be loaded into memory. Remember, they are static libraries - very much similar to those you compile into applications (zlib, for instance). I too wish there was a way around that.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 27/06/2006 at 00:41, xxxxxxxx wrote: however, you can change your code during runtime while debugging and also recompile changed parts during debugging.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 27/06/2006 at 13:33, xxxxxxxx wrote: Thank you! The other thing: What can be the reason: I put the original sdk back into the plugin-folder, launch cinema but then I don´t get the sdk-plugins? Jens
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 27/06/2006 at 13:56, xxxxxxxx wrote: If you have two versions of the sdk plugins, they will conflict in Plugin IDs if they have not been changed. Each plugin requires a unique Plugin ID acquired here. The plugin IDs in use by the first sdk folder are the same as those in the copied sdk folder, causing them not to load. I would not use the copies of the "cinema4dsdk" folder for writing plugins as you'll continuously run into this problem (except for maybe your own plugin's unique ID).
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 28/06/2006 at 05:18, xxxxxxxx wrote: Robert, If I take out the sdk-folder of the plugin-folder and replace it with another sdk-folder, they shouldn´t conflict, right? But sometimes (I don´t know when) after such a change, the sdk-plugins are not recognized by cinema. Jens
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 28/06/2006 at 07:48, xxxxxxxx wrote: As long as you are quitting Cinema 4D before swapping folders and then restarting afterwards, it should find them. Make sure that you are storing the 'swapped-out' sdk-folder in a folder external to Cinema 4D's "plugins" folder. I keep a folder called "plugins_backup" in the Cinema 4D install for this purpose.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 28/06/2006 at 13:55, xxxxxxxx wrote: Ok. You are right. It was my fault. The Problem was just that the sdk didn´t compile because of an error. Swapping works fine as described. Thank you, Jens
