Can I use SubDialogs in C.O.F.F.E.E. ?
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 20/04/2006 at 08:22, xxxxxxxx wrote: User Information:
 Cinema 4D Version: R9.5
 Platform: Windows ;
 Hi,is there a way to use SubDialogs in C.O.F.F.E.E.? I want to change part of a Dialog Layout according to a selection and the usage of different SubDialogs would be nice.
 But I cannot find anything like SubDialog or AttachSubDialog in the C.O.F.F.E.E. docs. Is that only available in C++?Thanks,
 Juergen
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 20/04/2006 at 11:08, xxxxxxxx wrote: It appears that this cannot be done in COFFEE. But you get about the same functionality with TabGroups. I use them rather than SubDialogs even with C++.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 21/04/2006 at 00:50, xxxxxxxx wrote: Thats a good one .. I'll try with tabs! thanks,
 Juergen
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 21/04/2006 at 00:56, xxxxxxxx wrote: You could write your own subdialog class which incorporates a dynamic layout. But tabs are probably the faster and more comfortable solution.
 THE POST BELOW IS MORE THAN 5 YEARS OLD. RELATED SUPPORT INFORMATION MIGHT BE OUTDATED OR DEPRECATED On 26/04/2006 at 06:41, xxxxxxxx wrote: one more thing:
 I don't want to show the user the different tabs, but only select the one that is currently correct for the choice ... how do i activate the right tab?Activate()does not work. Juergen
