    Can I use SubDialogs in C.O.F.F.E.E. ?
    5 Posts 0 Posters 499 Views
      On 20/04/2006 at 08:22, xxxxxxxx wrote:
      Cinema 4D Version:   R9.5
      is there a way to use SubDialogs in C.O.F.F.E.E.? I want to change part of a Dialog Layout according to a selection and the usage of different SubDialogs would be nice.
      But I cannot find anything like SubDialog or AttachSubDialog in the C.O.F.F.E.E. docs. Is that only available in C++?
      Juergen
        On 20/04/2006 at 11:08, xxxxxxxx wrote:
        It appears that this cannot be done in COFFEE. But you get about the same functionality with TabGroups. I use them rather than SubDialogs even with C++.
          On 21/04/2006 at 00:50, xxxxxxxx wrote:
          Thats a good one .. I'll try with tabs!
          thanks,
          Juergen
            On 21/04/2006 at 00:56, xxxxxxxx wrote:
            You could write your own subdialog class which incorporates a dynamic layout. But tabs are probably the faster and more comfortable solution. 🙂
              On 26/04/2006 at 06:41, xxxxxxxx wrote:
              one more thing:
              I don't want to show the user the different tabs, but only select the one that is currently correct for the choice ... how do i activate the right tab?
              Activate()
              does not work.
              Juergen
