    remove entry in attribute manager
    3 Posts 0 Posters 334 Views
      On 16/01/2006 at 03:11, xxxxxxxx wrote:
      Cinema 4D Version:   9.52
      I create some dynamic sliders in the attribute manager, I want remove some of them using the "remove entry" in the right clicking floating menu.
      I have set this parameter:
      Morph_Slider.SetBool(DESC_REMOVEABLE, TRUE);
      But the entry is still grayed.
      Any idea?
      Thank you.
      B->
        On 26/01/2006 at 11:59, xxxxxxxx wrote:
        I can't duplicate this. Try setting DESC_REMOVEABLE to TRUE in line 187 of morphmixer.cpp. Then the entry becomes enabled for me. Note that you will then get a MSG_DESCRIPTION_REMOVE_ENTRY message only. Nothing will be removed unless you do it yourself afaics.
          On 27/01/2006 at 00:51, xxxxxxxx wrote:
          Thank you,
          After looking at my code, I found the mistake: I was changing the parameters of the Slider:
          But that was the Checkbox parameters that I had to change.
          Morph_Select.SetBool(DESC_REMOVEABLE, TRUE);
          Another question: I have to save a custom array in the C4D scene.
          Is it possible and Is it true that I have to use the CustomDataType class?
          Thank you
          B->
