    AnimateObject on Deformed Objects
    14 Posts 0 Posters 1.3k Views
      On 28/11/2005 at 12:15, xxxxxxxx wrote:
      Yeah, AnimateObject() for the timeline tracks and SendModelingCommand() for the rest. (I don't know how it will work with time based deformers though.)
        On 07/06/2006 at 19:31, xxxxxxxx wrote:
        Hello Mikael,
        still not working here.
        I tried also AnimateDocument.. but the deformation are not calculated too.
        any help?
          On 08/06/2006 at 10:05, xxxxxxxx wrote:
          Do you not get any deformation at all or not just the deformations at the specified time?
            On 08/06/2006 at 15:32, xxxxxxxx wrote:
            i got deformation but when i force animateobject on the frame-1 the deformation is the same at frame
              On 30/09/2009 at 11:46, xxxxxxxx wrote:
              I still have this problem now.. can someone tell me why i can't get deformed geometry with animateobject and current state to objects?
              thanks 🙂
              renato
                On 30/09/2009 at 12:26, xxxxxxxx wrote:
                I've only had success with AnimateDocument() (now ExecutePasses() in R11.5) but it does work. This is how IPP figures are baked into static or PLA geometry in interPoser Pro.
                  On 30/09/2009 at 12:36, xxxxxxxx wrote:
                  Hello Robert,
                  uhm.. i tried with AnimateDocument.. but don't work.. Do i need to addevent or something?
                  thanks 😉
                  renato
                    On 30/09/2009 at 13:35, xxxxxxxx wrote:
                    Make sure to set the document time, call AnimateDocument(), and, yes, EventAdd() is a good idea.
                    doc->SetTime(stime);
                    #ifdef     C4D_R115
                    doc->ExecutePasses(NULL, TRUE, TRUE, TRUE);
                    #else
                    doc->AnimateDocument(NULL, TRUE, TRUE);
                    #endif
                    EventAdd();
                    where 'stime' is the BaseTime representing the frame.
                      On 30/09/2009 at 13:45, xxxxxxxx wrote:
                      Hello Robert,
                      i'm during rendering.. so eventadd.. will stop the renderdocument 🙂
                      I fear that i need to cache before all. then render.
                      what do you think?
                      renato
                        On 03/10/2009 at 07:39, xxxxxxxx wrote:
                        Howdy,
                        Is the deformer a child of the mesh, or is the mesh part of a hierarchy that is being deformed? I've noticed that CSTO only works properly when the deformer is a child of the mesh you need. If the mesh is in a deformed hierarchy, then CSTO needs to be invoked on the parent object to get the deformed mesh object. :o(
                        Adios,
                        Cactus Dan
                          On 03/10/2009 at 09:26, xxxxxxxx wrote:
                          Hello Dan 🙂
                          my scene it's just a cylinder with a bend inside it (child). 🙂
                          thanks
                          renato
