    Instance problem! Please help!
    3 Posts 0 Posters 416 Views
      On 24/07/2005 at 13:46, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      I'm just finishing my object generator plugin, and now I see, that it will not be rendered! In the editor all is fine, but it doesn't render to the picture viewer.
      The object generator uses instances of splines to generate a polygon object. It needs access to the original splines, so it reads the value from the instance's basecontainer using GetObjectLink(INSTANCEOBJECT_LINK, doc). But when rendering, the function returns NULL!
      Is the way how I try to access the original object not clean? Is there another way?
      Thanks for any help!
      Klaus
        On 30/11/2005 at 08:27, xxxxxxxx wrote:
        did you find a solution to this?
        i got the same problem over here
          On 30/11/2005 at 14:30, xxxxxxxx wrote:
          yes, I put my spline check after GetAndCheckHierarchyClone(). The resulting objects behave like real splines although they come from instances of splines. That solves the problem for me.
