    Eulumdat / IES
    Scheduled Pinned Locked Moved Plugin Requests
    18 Posts 0 Posters 3.5k Views
      On 04/04/2005 at 04:04, xxxxxxxx wrote:
      Does anybody know a possibility to import Eulumdat- or IES-Files as provided by several light-manufacturers? On the homepage of Erco for example you can download Eulumdat- / IES-Files of the whole range of lamps they produce - but I can't use them...
      Can anybody help me!?!
      Tobi
        On 10/05/2005 at 06:07, xxxxxxxx wrote:
        Hi Tobi
        Can you please clarify what you are trying to do? Which lighting program (Dialux or similar?)
        Regards
          On 10/05/2005 at 06:38, xxxxxxxx wrote:
          I'm trying to import the the EULUMDAT-files directly into Cinema4D R9. Till now I just see the posibility of converting the EULUMDAT-files into a bitmap-image (Terrabrush can do so), creating a new material with it and then applying the material to a lightsource.
          What I am searching for is a plugin what directly reads out the EULUMDAT-files.
          Tobi
            On 17/05/2005 at 03:02, xxxxxxxx wrote:
            Tobi
            You don't want a plug-in! You only need the files. I thought that you could download the Erco files without the DIALux plug-in (but I'll stand corrected!).
            Regards
              On 17/05/2005 at 03:08, xxxxxxxx wrote:
              Tobi
              This is the link:
              http://www.erco.com/~klickmeister/km_ls_download/ls_download.pl?
              Regards
                On 17/05/2005 at 03:55, xxxxxxxx wrote:
                I've just downloaded the whole archive of EULUMDAT-files from Erco a few weeks ago - that works without the DIALux-plugin.
                But isn't there a faster way to use the light information? (I mean: I don't want to open them in Terrabrush on a PC, save them as a bitmap, transfer them back to my Mac, define a new material and put this as slide on my light in Cinema4D.)
                What I meant is a plugin so that my Cinema4D-light can directly read out / use the informmation of the EULUMDAT- or IES-files without involving any other programs and PC's
                best regards
                Tobi
                  On 17/05/2005 at 05:21, xxxxxxxx wrote:
                  Tobi
                  The plug-in is for DIALux only. It contains illumination data, basic luminaire size data and that is it. No colour of luminaire, texture or any other information. So I think you're stuck with what you've got.
                  regards
                  Bernard
                    On 17/05/2005 at 05:32, xxxxxxxx wrote:
                    Yes, I think so too: 😞
                    I've searched the whole web for another possibility, but no way. Let's wait for release 10 and hope Maxon can build anything like that. It would make the work easier and the lights would look more realistic.
                    Thanks for your help
                    Tobi
                      On 17/05/2005 at 05:37, xxxxxxxx wrote:
                      Oh well, never mind, eh!
                      Toodle pip!
                      B
                        On 17/05/2005 at 15:33, xxxxxxxx wrote:
                        What kinda information does this file format actually hold? Which c4d light parameters are affected? What kind of file format is that?
                        If you have a link I could have a look at it and if you need such a plugin, maybe we could arrange sth (of course not free of charge).
                          On 18/05/2005 at 01:29, xxxxxxxx wrote:
                          It is not so urgent in the way to develop a plugin just for me... 🙂
                          But thanks a lot.
                          If you go on www.erco.de you'll find the section download and there you'll find the EULUMDAT- and IES-files.
                          The file format is .ldt (EULUMDAT). It discribes several parameters which are not all included in the light parameters of cinema 4D, as there are e.g. intesity (Watt), lightning-angel and the combination of them, relativly to the distance.
                          For exact information you've got to read the discription at Erco for example, my English is not so well to explain these things in correct terms. Sorry...
                          Regards
                          Tobi
                            On 19/05/2005 at 13:50, xxxxxxxx wrote:
                            Hi eneryone!!! i am architect and i could use the ies files, because some times it is very importand to know the exact amount that you get from the light in a 3d scenery (which by the way will become a true space). will people bump into each other (after sunset) if i use 4 pair of lights or they will go blind from the high intencity???
                            a plugin that, can ensure e.g 100% brightness stands for a lamp of 100Watts in the real world (50% -> 50Watts and so on), can tell the difference between spolights with QR, or CDMR or AR70,  AR111, lamps, it woyld be a great advantage for architects.
                              On 23/09/2005 at 04:29, xxxxxxxx wrote:
                              Hi everyone!
                              I'm a lighting designer. It's very important to use IES or Eulumndat photometric light in any 3D software.
                              I invite to take vision to you of the software Lightscape of Discreet (only PC sigh) o Form Z (PC and Mac, but very slow) in order understanding what I mean. I refer in particular to the
                              visualization to colors in lux. All the software use Radiosity like C4D. But nothing about IES / eulumndat and calculation about amount of light. There is anyone in C4D Staff that can help us and support our request?
                                On 12/03/2006 at 15:28, xxxxxxxx wrote:
                                since there is no such think in c4d, i decided to give it a try and make my own plugin.
                                i could really use some infomation about lighting and how it interacts with material of different nature and colour.
                                ecorelli, since you are a lighting designer, maybe you could provide some data to start with.
                                tnx in advance.
                                  On 20/06/2006 at 10:01, xxxxxxxx wrote:
                                  georgedrakakis..
                                  Hows going with that plugin?
                                  Im another interested in this, starting to learn the SDK and thinking about to try to do it.
                                    On 20/06/2006 at 10:31, xxxxxxxx wrote:
                                    georgedrakakis:
                                    The IES and Eulumdat information rappresent the distribution of the light in the space.
                                    Here can You have information about syntax of standard files:
                                    http://www.helios32.com/Eulumdat.htm
                                    http://www.ledalite.com/resources/software/
                                    http://www.helios32.com/resources.htm
                                      On 21/06/2006 at 14:12, xxxxxxxx wrote:
                                      Quote: Originally posted by rodrigomurcia on 20  June 2006
                                      > georgedrakakis..
                                      hey rodrigomurcia,
                                      i'm quite busy right now, so things didn't go as fast as i expected.
                                      i'va managed to render scenes, both exterior and interior, with the same render settings. what i need now is to set the lights as true as possible.
                                      i'm sure that ecorelli's information will be trully usefull.
                                      maybe i'll post some images of what i've done so far.
                                      george
                                        On 21/06/2006 at 14:14, xxxxxxxx wrote:
                                        Quote: Originally posted by ecorelli on 20  June 2006
                                        > georgedrakakis:
                                        hey ecorelli,
                                        thank you very much for the info.
                                        i'll give it a try, but not right now, cause i'm extremely busy with some projects of mine.
                                        george
