    NET RENDER
    Scheduled Pinned Locked Moved General Discussion
    5 Posts 0 Posters 980 Views
      On 08/03/2005 at 20:19, xxxxxxxx wrote:
      Does anyone know how I can make the Net Render Client start on startup? I know how to start it up upon login, but not startup. I use OS X.
        On 31/03/2005 at 11:22, xxxxxxxx wrote:
        Tony,
        It is easy but kind of hidden. Go into your system prefs - select accounts - there you will find a tab for startup items, just put the clientin there, works great.
        ed
          On 31/03/2005 at 14:45, xxxxxxxx wrote:
          Yeah, that works on login, but not on startup. I need it to be on no matter who logs in. All the time.
          --Tony
            On 26/04/2005 at 23:03, xxxxxxxx wrote:
            As far as I know it is not possible to start the client at startup. But if you are the system administrator you can define the client application as a startup-icon for every user...
            --tobi
              On 27/04/2005 at 06:58, xxxxxxxx wrote:
              Thank you Tobi. It looks like it needs to be compiled differently, so it can go into the startup items folder. It sure would be nice if Maxon would do this! Just think of the possibilities.
              --Tony
