    [Python] SendModelingCommand()
    Scheduled Pinned Locked Moved Bugs
    3 Posts 0 Posters 1.1k Views
    • H Offline
      Helper
      On 02/12/2016 at 13:21, xxxxxxxx wrote:
      Cinema 4D Version:   18
      Platform:     Mac  ;
      Language(s) :       PYTHON  ;
      there seems to be an issue with c4d.utils.SendModelingCommand() using MCOMMAND_JOIN as command ID in Release 18.048.
      from c4d import gui
      def main() :
          olist = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_0)
          settings = c4d.BaseContainer()                 # Settings
          res = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_JOIN,
                                              list = olist,
                                              bc = settings,
                                              doc = doc)
          doc.InsertObject(res[0].GetClone())
      if __name__=='__main__':
      While with Release 17 the results are as expected. SMC connects all selected objects.
      In R18.028 the result contains only one object of the selected object.
      Greets
      Peter
      • H Offline
        Helper
        On 05/12/2016 at 02:39, xxxxxxxx wrote:
        Hi Peter,
        For MCOMMAND_JOIN to always work the objects to join must be children of a parent object, a null for instance.
        Pass the list argument as [null] with null the parent null object variable.
        The command worked pre-R18 with multi-selection of objects but now the objects to join have to be arranged under a parent object.
        • H Offline
          Helper
          On 05/12/2016 at 07:15, xxxxxxxx wrote:
          Hi Yannick,
          thank you for your explanation. I'll give it a try.
          Are there other Modeling IDs with a different behavior in R18?
