    ContextMenu
    4 Posts 0 Posters 795 Views
    • H Offline
      Helper
      On 31/01/2003 at 08:29, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Platform:
      in the TreeViewFunctions class.
      there is the function CreateContextMenu.
      this  provides a way to deliver a right mouse click ContextMenu
      there are 2 functions in there already.
      remove and remove all.
      "remove" calls delete when clicked
       "remove all" seems to call nothing.
      I find the text strings for these menu entrys at 90000 and 90001
      in the class definition , the comment :
      "own elements should start at ID_TREEVIEW_FIRST_NEW_ID"
      this is 90000.
      so my questions are:
      how do I arrange such an element.
      how do I tell it which function to call.
      how do I react when its clicked ,ect
      how do i fill the thing in  🙂
      there seems to be no usefull information on this type of menu entry.
      • H Offline
        Helper
        On 31/01/2003 at 10:10, xxxxxxxx wrote:
        Hi Paul
        Have a look at TreeViewF::ContextMenu (customgui_listview.cpp). If the command is Remove, DeletePressed is called, otherwise the ContextMenu method from TreeViewFunctions. You must override TreeViewFunctions::ContextMenu to handle your context menu messages.
        To fill the container, follow the instructions in the ShowPopupMenu help.
        • H Offline
          Helper
          On 01/02/2003 at 03:08, xxxxxxxx wrote:
          thanks , that does help .
          however
          LONG ShowPopupMenu(CDialog* cd, LONG screenx, LONG screeny, const U face=Times New Roman color=#0000ffBaseContainer/U& bc, LONG flags = POPUP_RIGHT|POPUP_EXECUTECOMMANDS)
          is returning a LONG number , which is just what I want.
          but when using the TreeViewFunctions class , there seems to be no way to find out which button was pressed.
          the CreateContextMenu displays my menu and will execute any system commands that are in there.
          however , i want to get the id that got clicked , so I can do some non-system commands.
          how can this id be found?
          • H Offline
            Helper
            On 01/02/2003 at 04:37, xxxxxxxx wrote:
            ok,ok , i get 10 points fro being blind as a bat !!!
