    CUSTOMGUI_PROGRESSBAR
    Scheduled Pinned Locked Moved PYTHON Development
    5 Posts 0 Posters 1.0k Views
    • H Offline
      Helper
      On 02/02/2016 at 07:30, xxxxxxxx wrote:
      How do I use the CUSTOMGUI_PROGRESSBAR.
      I cannot find any examples?
      -Pim
      • H Offline
        Helper
        On 02/02/2016 at 09:36, xxxxxxxx wrote:
        Hi Pim,
        The CUSTOMGUI_PROGRESSBAR is setup and updated using BFM_SETSTATUSBAR GUI message and its related BFM_STATUSBAR container options.
        Here's a simple example:
        from c4d import gui
        class TestDialog(gui.GeDialog) :
            PROGRESSBAR = 1001
            def __init__(self) :
                self.progress = 0
            def StopProgress(self) :
                self.SetTimer(0)
                progressMsg = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR)
                progressMsg.SetBool(c4d.BFM_STATUSBAR_PROGRESSON, False)
                self.SendMessage(self.PROGRESSBAR, progressMsg)
            def CreateLayout(self) :
                self.SetTitle("ProgressBar Example")
                self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP, cols=0, rows=1)
                self.AddCustomGui(self.PROGRESSBAR, c4d.CUSTOMGUI_PROGRESSBAR, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
                self.GroupEnd()
            def InitValues(self) :
                self.SetTimer(1000)
            def Timer(self, msg) :
                self.progress += 1
                progressMsg[c4d.BFM_STATUSBAR_PROGRESSON] = True
                progressMsg[c4d.BFM_STATUSBAR_PROGRESS] = self.progress/10.0
            def Message(self, msg, result) :
                if msg.GetId() == c4d.BFM_TIMER_MESSAGE:
                    if self.progress==10:
                        self.StopProgress()
                        self.Close()
                return gui.GeDialog.Message(self, msg, result)
            def AskClose(self) :
                self.StopProgress()
                return False
        if __name__=='__main__':
            dialog = TestDialog()
            dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=0, defaulth=400, defaultw=400)
        A progress bar can also be added to a dialog within a status bar with GeDialog.ScrollGroupBegin().
        • H Offline
          Helper
          On 02/02/2016 at 12:21, xxxxxxxx wrote:
          Is there a speecial reason you use SubDialog as the parent class? Just interested.
          • H Offline
            Helper
            On 03/02/2016 at 02:45, xxxxxxxx wrote:
            Hi Niklas,
            Oooops, I had not seen the dialog was declared as a SubDialog and not as a normal GeDialog.
            I updated the code I posted as it was missing the last progress step and other minor things have been fixed (call SetTimer() in InitValues(), StopProgress() etc.)
            • H Offline
              Helper
              On 05/02/2016 at 05:36, xxxxxxxx wrote:
              Great, thank you.
              -Pim
