    Bodypaint Bitmap Dirty status
    8 Posts 0 Posters 1.2k Views
      On 13/12/2014 at 09:42, xxxxxxxx wrote:
      has anyone made experiences with Bodypaint Bitmaps.
      If I check the dirty state of a bitmap like:
        Tex = bodypaint.PaintTexture.GetSelectedTexture()
        actlay= Tex.GetActive()
        if actlay.IsInstanceOf(c4d.OBJECT_PAINTLAYERBMP) == True:
            bmp = actlay.ToPaintLayerBmp()
            bmp.GetDirty()
      I´ll get this error message:
      SystemError: /perforce_buildsystem_osx/c4d_mx_buildsystem_osx/release/16.0/modules/python/source/i_getargs.cpp:1616: bad argument to internal function
      I´m not allowed to set a zero flag as it is suggested in the docs:
      ``PaintBitmap.GetDirty( _flags_ )[URL-REMOVED]
      Thanks in advance
      Martin
        On 13/12/2014 at 11:19, xxxxxxxx wrote:
        You've created  a paint layer bitmap. Which doesn't have a GetDirty() method.
        You'll need to convert it to a BaseBitmap() type using GetPixelCnt() to loop through it and copy the color values to a new BaseBitmap with SetPixelCnt().
        Then you should be able to use GetDirty() on it.
          On 13/12/2014 at 12:34, xxxxxxxx wrote:
          Hello Scott,
          yes thanks! I see.
          But it doesn´t make sense to me as im able to use the other members of the class with
          I want to avoid recalculating the Bitmaps on every event message in my plugin.
          I copied the  BP layer structure to a treeviewcustomgui and an userarea in my dialogplugin.
          That´s why I was searching for a fast indicator that the user changed something at the PaintBitmap
          and I thought GetDirty should be good enough.
          Do you have an idea to solve this in fast manner.
          Thanks in advance
          Martin
            On 13/12/2014 at 13:19, xxxxxxxx wrote:
            No idea.
            I've never tried using the layer images in other GUI's.
            Sorry.
              On 13/12/2014 at 15:23, xxxxxxxx wrote:
              ok.
              By the way the treeviewcustom gui on your website was a good resource to begin with.Thanks
              Martin
                On 15/12/2014 at 07:03, xxxxxxxx wrote:
                if I try to follow along with Scotts suggestion.
                my dirty status is always 1, as expected.
                Because I have to initialise the bitmap in the first place or load it from a path to use GetPixelCnt()/SetPixelCnt()
                So is my assuption right that the dirty status of a bitmap only reflects the count of how often a bitmap was saved with c4d and therefore it is not possible to detect if a bitmap has changed without saving it to disc?
                Could someone please throw light on this issue?
                Thanks in advance
                Martin
                  On 15/12/2014 at 10:45, xxxxxxxx wrote:
                  the dirty count is increased every time a part of the bitmap is changed. Unfortunately there is a bug in PaintBitmap.GetDirty(). A bug report was filed.
                    On 15/12/2014 at 13:46, xxxxxxxx wrote:
                    Hello Sebastian,
                    thanks for the bug report,
                    I hope we can use it soon.
                    Best wishes
                    Martin
