    Bodypaint Layer Bitmap [SOLVED]
    8 Posts 0 Posters 1.6k Views
      On 04/12/2014 at 02:16, xxxxxxxx wrote:
      I hope someone can help me with this!
      I can´t find an easy way to get a Bitmap out of a Bodypaint layer.
      I want to show those Layers on an Userarea, how can I do this?
      Additionally it seems to me that some bodypaint features are not available in Python?
      (at the bottom of the thread)
      What I´ve found out so far:
      if there is an active BB texture;
        tex = bodypaint.PaintTexture.GetSelectedTexture()
        texturename = tex.GetFilename()
        actlay = tex.GetActive()
      if one have to load a new BB texture;
        #loaddialog
        texturename =  c4d.storage.LoadDialog(type= c4d.FILESELECTTYPE_IMAGES, title="Load Hdr", flags=c4d.FILESELECT_LOAD)
        #pass it to BB and make itself and the first layer active
        settings = c4d.BaseContainer()
        settings.SetFilename(c4d.LOADTEXTURE_FILENAME, texturename)
        tex = bodypaint.SendPainterCommand(c4d.PAINTER_LOADTEXTURE, doc=doc, tex=None, bc=settings)
        if not tex:return
        lay = tex.GetFirstLayer()
        tex.SetActiveLayer(lay, activatetexture=True, show=True)
        #get the active layer
        print actlay, "layer"
        #read layerdimensions
        res =  actlay.GetBoundingBox()
        xres = res['x2']
        yres = res['y2']
        #check attributes
        print actlay[c4d.ID_BASELIST_NAME]
        print actlay[c4d.ID_PAINTBITMAP_PREVIEW]
        print actlay[c4d.ID_PAINTLAYER_BLEND]
        print actlay[c4d.ID_PAINTLAYER_OPACITY]
        print actlay[c4d.ID_PAINTLAYER_SHOW]
        #add a new layer
        print tex.AddLayerBmp(insertafter=ActLay, useundo=True, activate=True)
        #save the whole texture and pass it to the userarea is not what I want
        #orig = bitmaps.BaseBitmap()
        #orig.InitWith(texturename)
        #bitmaps.ShowBitmap(orig)
      -How to add a new layer on top of the last one? Why only insertafter?
      -[c4d.ID_PAINTBITMAP_PREVIEW]is always None?
      Thanks in advance
      Martin
        On 04/12/2014 at 06:26, xxxxxxxx wrote:
        to get the raw content of a bitmap layer use GetPixelCnt()[URL-REMOVED]. Then you can copy this data into a BaseBitmap with SetPixelCnt()[URL-REMOVED]. You find examples how to use this functions in the painting examples in the C++ and Python SDK like SculptPaintBrush[URL-REMOVED].
          if actlay.IsInstanceOf(c4d.OBJECT_PAINTLAYERBMP) == True:
              bmp = actlay.ToPaintLayerBmp()
              xres = bmp.GetBw()
              yres = bmp.GetBh()
              size = xres * yres
              if size == 0:
              colorMode = bmp.GetColorMode()
              # prepare storage
              sq = storage.ByteSeq(None, size*c4d.COLORBYTES_RGB)
              inc = 3
              # read data
              for row in xrange(yres) :
                  offset = sq.GetOffset(row*(xres*inc))
                  bmp.GetPixelCnt(0, row, xres, offset, colorMode, c4d.PIXELCNT_0)
              # prepare bitmap
              baseBitmap = bitmaps.BaseBitmap()
              baseBitmap.Init(xres,yres,)
              # write data
                  baseBitmap.SetPixelCnt(0, row, xres, offset, inc,colorMode, c4d.PIXELCNT_0)
              # save
              filename = c4d.storage.SaveDialog(title="Save preview")
              baseBitmap.Save(filename,c4d.FILTER_TIF)
        AddLayerBmp()[URL-REMOVED] should accept None as an argument for "insertafter". This is a bug. ID_PAINTBITMAP_PREVIEW returns a CUSTOMDATATYPE_BITMAPBUTTON[URL-REMOVED] which is currently not supported in Python.
          On 04/12/2014 at 07:00, xxxxxxxx wrote:
          Hello Sebastian,
          Thank you very much! Tremendous help as always!
          Just two hours ago I started with storage and bytesequence, but could´nt get it to work.
          I tried it with the new R16 function
          PaintLayerBmp.GetPixelCnt[URL-REMOVED]
            sq = storage.ByteSeq(None, xres*yres*inc)
            ActLay.GetPixelCnt(0, 0, cnt, sq , dstmode= c4d.COLORMODE_RGB, flags= c4d.PIXELCNT_0)
          But no luck! Do you have a working example ?
          AddLayerBmp() does not accept None.
          the resulting errormessage:
          TypeError: argument 1 must be c4d.modules.bodypaint.PaintLayer, not None
          Could you please give it a try?
          Thanks again
          Martin
            On 04/12/2014 at 07:43, xxxxxxxx wrote:
            Hi Martin,
            Here a script that read a bitmap file, converts it to spherical and writes it back.
            import c4d, math
            from c4d import bitmaps, gui, storage
            from c4d import plugins
            # spherical projection
            # y=y, x=x*cos(y)
            BUTTON_ID_SELECT = 1001
            MY_PATH = 1003
            MY_FILEDIMENSIONS = 1007
            MY_GOBUTTON = 100014
            MY_LINKBOX = 100015
            #global variables
            width = 0
            height = 0
            orig = 0
            path = None
            Tolerance = 0.0000001
            masterRadius = 1
            derivedRadius = math.pi/2
            class YourDialog(gui.GeDialog) :
                def CreateLayout(self) :
                    self.SetTitle("Spherical Projection.")
                    self.GroupBegin(id=8000, flags=c4d.BFH_LEFT, cols=2)     #, rows=1)
                    self.GroupBorderSpace(10, 10, 10, 20)
                    self.AddButton(BUTTON_ID_SELECT, flags=c4d.BFH_LEFT, initw=145, inith=30, name="Select Input file")
                    self.element = self.AddStaticText(id=MY_PATH, flags=c4d.BFH_MASK, initw=600, name="   ", borderstyle=c4d.BORDER_NONE)
                    self.element = self.AddStaticText(id=11004, flags=c4d.BFH_MASK, name="File Dimensions   ", borderstyle=c4d.BORDER_NONE)
                    self.element = self.AddStaticText(id=MY_FILEDIMENSIONS, flags=c4d.BFH_MASK, initw=600, name="   ", borderstyle=c4d.BORDER_NONE)
                    self.AddSeparatorH(inith=80)
                    self.AddButton(MY_GOBUTTON, c4d.BFV_MASK, initw=145, name="Go!")
                    self.GroupEnd()
                def Command(self, id, msg) :
                    global width, height, orig, path, copy
                    if (id == BUTTON_ID_SELECT) :
                        path = storage.LoadDialog(type=c4d.FILESELECTTYPE_IMAGES, title="Please Choose a 32-bit Image:")
                        print "Path: ", path
                        if (path != None) :
                            # Create and initialize selected image
                            if orig.InitWith(path)[0] != c4d.IMAGERESULT_OK:
                                gui.MessageDialog("Cannot load image \"" + path + "\".")
                            # Get selected image infos
                            width, height = orig.GetSize()
                            #print "w+h: ", width, " - ", height
                            bits = orig.GetBt()
                            #print "bt: ", bits
                            self.SetString(MY_PATH, path)
                            self.SetString(MY_FILEDIMENSIONS, str(width)+"X"+str(height)+ "  Bits: "+str(bits))
                        # Create the copy and initialize it
                        copy = bitmaps.BaseBitmap()
                        copy.Init(width, height, bits)
                    #return True
                    if (id == MY_GOBUTTON) :
                        #c4d.EventAdd()
                        #self.Close()
                        #print "Gobutton path: ", path
                        if (path == None) :
                            gui.MessageDialog ("No Input File selected!")
                            return -1
                        ret = SphericalProjection(self.GetString(MY_PATH))
                        #print "Showbitmaps orig + copy"
                        bitmaps.ShowBitmap(copy)
                def DestroyWindow(self) :        #Use this method to toggle the switch back to it's original off state
                    #obj[c4d.ID_USERDATA, 1]=0
            def SphericalProjection(path) :
                global width,height,orig
                c4d.gui.SetMousePointer(c4d.MOUSE_BUSY)
                if not path: return
                height2 = height / 2
                width2 = width / 2
                for ix in range(width) :
                    for iy in range(height) :
                        ycos = math.sin(math.radians(90.0/height2)*iy)
                        x = width2 + (width2-ix)*ycos
                        r,g,b = orig.GetPixel(int(x), iy)
                        copy.SetPixel(width-ix, iy, r, g, b)
                dlg = YourDialog()
                dlg.Open(dlgtype= c4d.DLG_TYPE_ASYNC, defaultw=400)       #, xpos=600, ypos=500, defaultw=200, defaulth=200)
              On 04/12/2014 at 08:53, xxxxxxxx wrote:
              Hello Martin,
              do you have any questions about the above example or the linked examples?
              As stated above, it is a bug that AddLayerBmp() does not accept None.
                On 04/12/2014 at 09:27, xxxxxxxx wrote:
                @Sebastian
                ahh,
                I see, I assigned the bug statement to the bitmapbutton for whatever reason.Thanks.
                The example is pretty clear.
                You just used the new GetPixelCnt method?
                Thanks!
                For the Limit list on support site, should I write an email that it´s not possible in Python, or will this restrictions registered automatically?
                @Pim
                Thanks!
                Best wishes
                Martin
                  On 05/12/2014 at 01:50, xxxxxxxx wrote:
                  just in case someone needs to know.
                  To avoid the layer insertion point bug, one can use GeListNode class commands like:
                    #add a new layer
                    newlayer = tex.AddLayerBmp(insertafter=actlay, useundo=True, activate=True)
                    # as (insertafter= None) does not work a workaround to paste the new layer on top of the list
                    newlayer.InsertBefore(tex.GetFirstLayer())
                    #to avoid problems with previous loaded textures, set the first layer activ
                    first = tex.GetFirstLayer()
                    tex.SetActiveLayer(first, activatetexture=True, show=True)
                  @Sebastian
                  could you please explain what´s the difference between GetPixelCnt with a Bitmap and a BodyPaint layer?
                  I didn´t get it.
                  Thanks in advance
                  Martin
                    On 05/12/2014 at 05:42, xxxxxxxx wrote:
                    PaintLayerBmp.GetPixelCnt()[URL-REMOVED] and BaseBitmap.GetPixelCnt()[URL-REMOVED] are two different methods of two different classes. They are used pretty much the same way; the only difference is that BaseBitmap.GetPixelCnt() allows you to define a byte increment per pixel for the output buffer.
