    baking script vs baking plugins [SOLVED]
    5 Posts 0 Posters 642 Views
      On 27/11/2014 at 03:45, xxxxxxxx wrote:
      Hi guys,
      I just moved from 3ds max to c4d and so I m moving from maxscript to python at the same time.
      I am trying to write a script to automate baking on selected object, to be more specific creating a null and matching his position/rotation/scale to the object and keying the null on every frame.
      In maxscript I would have done a for loop looking like that (baking the object named 'objectToBake' for a 250 frames long scene) :
      target=$objectToBake
      obj=point()   //create null
      for i=0 to 250 do
      sliderTime = i
      obj.transform=target.transform
      obj.addkey (this won t be that line but it s just the concept)
      Then in c4d I did the same thing in python. So within the object to bake selected I run this:
      from c4d import gui
      scene_fps=doc[c4d.DOCUMENT_FPS]
      sceneStart=doc[c4d.DOCUMENT_MINTIME]
      sceneEnd=doc[c4d.DOCUMENT_MAXTIME]
      obj=c4d.BaseObject(5140)
      doc.InsertObject(obj)
      target=doc.GetActiveObject()
      posTrack=obj.FindCTrack(c4d.ID_BASEOBJECT_REL_POSITION)
      if not posTrack:
          posTrack=c4d.CTrack(obj,c4d.ID_BASEOBJECT_REL_POSITION)
          obj.InsertTrackSorted(posTrack)
      curve=posTrack.GetCurve()
      for i in range(0,91) :
          doc[c4d.DOCUMENT_TIME]=c4d.BaseTime(i,scene_fps)
          newPos=target[c4d.ID_BASEOBJECT_REL_POSITION]
          obj[c4d.ID_BASEOBJECT_REL_POSITION]=newPos
          keySet=curve.AddKey(c4d.BaseTime(i,scene_fps))
          posTrack.FillKey(doc,obj,keySet["key"])
          c4d.EventAdd()     // here is my issue, can t update during a loop
      And basically it works only on the first frame.
      From what I read it s all because script in c4d are singlethread and so the positions don t update during the loop even though I update the time slider position during the loop.
      So now I m trying to do it through a plugin hoping now my positions will be updated during the loop.
      Is a plugin the good way to do it ?
      I also want to create an user inteface to select the objects I want to bake and all that stuff. And then I was wondering if this go with the plugin as well and if a plugin is the only way to do it.
      Hope all this is not to confusing but I m a bit lost with what script are doing and what plugins are for in c4d.
      Would be great if you can let me know if I m in the good direction or not.
      To make it very simple, I just want to know what is the way to run commands in a loop and having everything updated at each loop iteration.
      Thank you !
        On 27/11/2014 at 04:03, xxxxxxxx wrote:
        you might have a look at this thread, there is a basic bake script,
        https://plugincafe.maxon.net/topic/8163/10637_bake-object&KW=bake
        There is a sync message that will update your scene like:
        c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
        You can use a script even if you want to use a dialog.
        A async dialog plugin might be a good choice, too.
        Best wishes
        Martin
          On 28/11/2014 at 00:38, xxxxxxxx wrote:
          Hello and welcome,
          setting the current frame of a document is not as simple as:
          You can use SetTime()[URL-REMOVED] to set the current frame of a document. However this will not animate the scene. To get the state of an object in a certain frame you have to animate the scene since the state of an object may depend on other objects like deformers, effectors etc. To animate the scene use ExecutePasses()[URL-REMOVED]:
            for i in range(0,90) :
                time = c4d.BaseTime(i,fps)
                doc.SetTime(time)
                doc.ExecutePasses(None,True,True,True,c4d.BUILDFLAGS_0)
            On 28/11/2014 at 02:49, xxxxxxxx wrote:
            Thanks Sebastian for the detailed explanation!
            Always great to see how you straighten things out!
            That´s what the
            def SetCurrentFr(FR, doc) :
            function in my script does.
            Just a small additional note.
            After some experiments with baking mograph, dynamics, etc.
            I recommend to use the
                              key = curve.AddKey(CurrTime)['key']
                              tr.FillKey(doc,m,key)
            instead of
                          key.SetValue(curve, val)
            for translation keys.
            Best wishes
            Martin
              On 05/12/2014 at 08:22, xxxxxxxx wrote:
              Hello had,
              was your question answered?
