    Points in local and global coordinates [SOLVED]
    Scheduled Pinned Locked Moved PYTHON Development
    3 Posts 0 Posters 953 Views
    • H Offline
      Helper
      On 24/11/2014 at 17:09, xxxxxxxx wrote:
      I am confused as to how some of this works. I've read the documentation, tried to implement it, and I just can't seem to get it to work. I read up on how to do the math on matrices, however, I am a bit lost.
      I've looked into numPy but I currently don't have it.. and I would rather not use something that would have to be installed on every machine just to use this particular code.
      Here's the rundown.
      In the documentation it says:
      What if you have a position in global coordinates and want to move an object to that position? Then you need a transformation back from global coordinates to the object's local position coordinates. Mathematically this is done by multiplication by the global matrix' inverse. If Mg is a matrix in global space and Mag is object a's global matrix, then Mag-1*Mg equals the first matrix' in a's local coordinates.
      It also says that you don't need to do the math because there are the functions:
      SetMl (ml) and SetMg (mg)
      Those only work for the baseObject.. and not a point.
      I've tried to plug in the Mag-1*Mg into some test code, just so I can see if the numbers come out correctly. However, I don't understand how to use that correctly. From my understanding of the documentation and the provided code, Mag is globalPoint and Mg would be worldSpaceCoords.
          doc = c4d.documents.GetActiveDocument ()
          op = doc.GetActiveObject ()
          worldSpaceCoords = op.GetMg()
          allPoints = op.GetAllPoints()
          for i,a in enumerate (allPoints) :
              localPoint = op.GetPoint (i)
              print 'local', localPoint
              globalPoint = localPoint * worldSpaceCoords
              print 'global', globalPoint
              backLocalPoint = globalPoint-1*worldSpaceCoords
              print 'back to local', backLocalPoint
              print '--'
      Currently I'm running into the following error:
      TypeError: unsupported operand type(s) for -: 'c4d.Vector' and 'c4d.Matrix'
      I'm lost in the math as to how to get back to the local coordinates.
      • H Offline
        Helper
        On 25/11/2014 at 01:29, xxxxxxxx wrote:
        as the documentation says "Mag" should be a matrix. In your code you try to handle a vector:
        Also, "Mag-1" does not mean "minus one". It stands for the inverse matrix. You can create the inverse matrix using Python's "invert" operator:
              inverseMatrix = ~worldSpaceCoords
              backLocalPoint = globalPoint * inverseMatrix
        You find some examples of complex matrix use in the SpherifyModifier example[URL-REMOVED].
        best wishes,
        Sebastian
        [URL-REMOVED] @maxon: This section contained a non-resolving link which has been removed.
        • H Offline
          Helper
          On 25/11/2014 at 16:23, xxxxxxxx wrote:
          I thought the documentation sounded weird with the -1 in there.
          I was looking for the syntax for the invert operator. Everything is working now, which is fantastic thanks to you!
