    dynamic ui in c4d python sdk
    Scheduled Pinned Locked Moved PYTHON Development
    3 Posts 0 Posters 405 Views
    • H Offline
      Helper
      On 06/03/2014 at 01:16, xxxxxxxx wrote:
      hi,
      i've checked the c4d python sdk for Dialog, it has a method 'CreateLayout', seems all the ui needs to be created here. i need to add/delete panel based on a button click event in command handler, i tried to put it in event handler (out of createlayout), seems it doesn't work.
      does anyone know about how to do a dynamic ui with c4d python sdk? it would be grateful if there's a sample.
      another question is, is there a collapsable panel/group in python sdk, i need a panel that should have a checkbox in the bar (it could be checked so that it could be deleted with a delete button)?
      do i need to derived from GeUserArea to define myself?
      thanks a lot,
      • H Offline
        Helper
        On 15/03/2014 at 11:55, xxxxxxxx wrote:
        You should create a group around the part you want to modify. When you want to change the layout (e.g. in your overwritten GeDialog.Command function) you flush the group with LayoutFlushGroupURL-REMOVED, and can create your  new elements afterwards.
        Commit your changes with a call of LayoutChangedURL-REMOVED.
        Cheers, s_rath
        [URL-REMOVED] @maxon: This section contained a non-resolving link which has been removed.
        • H Offline
          Helper
          On 16/03/2014 at 03:26, xxxxxxxx wrote:
          You can hide elements with GeDialog.HideElements (missing in the documentation)
          Check this out: https://developers.maxon.net/forum/topic/7549/9454_collapsingfoldable-groups-in-python&PID=37336#37336
