    Why is "BaseBitmap.__getitem__" bmp(x,y) only 8Bit
    Scheduled Pinned Locked Moved PYTHON Development
    3 Posts 0 Posters 330 Views
    • H Offline
      Helper
      On 02/03/2014 at 06:50, xxxxxxxx wrote:
      Why is "BaseBitmap.__getitem__" bmp(x,y) only 8Bit?
      It seems strange hence all the other color Values are more than enough but the bmp functions can only output 8bit values?
      Perhaps I am on the wrong track, i need to read the pixel color of a rendered image to check against a color setting made in c4d.
      How do i read the rendering in 16bit instead of 8bit?
      From the SDK:
      _Example:
      r, g, b = bmp[5, 5] #returns the color of a pixel at position x(5), y(5)
      Return type:     tuple(int, int, int)
      Returns:     The color of a pixel. Range between 0-255._ <-----!!!
      Can it be converted to a C4D Vector with full color spectrum ? I guess I'll lose accuracy?
      confused ...
      • H Offline
        Helper
        On 02/03/2014 at 13:05, xxxxxxxx wrote:
        ah found something
        (to use higher bit depths or multiple channels, see MultipassBitmap).
        but how do i read the color values of each pixel of a multipass image?
        kind regards
        mogh
        • H Offline
          Helper
          On 04/03/2014 at 11:34, xxxxxxxx wrote:
          So I managed to read my BMP with this:
          http://www.maxonexchange.de/sdk/CINEMA4DPYTHONSDK/help/modules/c4d.bitmaps/BaseBitmap/index.html#BaseBitmap.SetPixelCnt
          especially this part of the script:
              Example: RGB value of first pixel (only for 32 bits)
              import struct
              r, g, b = struct.unpack("fff", sq[0:12])
              print r, g, b
          but I get strange RGB Values of my 32Bit Image.
          I set the Object to RGB Float Values and get these float values from my 32Bit Pixels.
          Testcolor: Vector(0.1, 0.2, 0.3) -> 32Bit RGB: 0.0100228255615 0.0331047661602 0.0732389613986
          Testcolor: Vector(0.4, 0.5, 0.6) -> 32Bit RGB: 0.13286831975   0.214041143656 0.318546801805
          Testcolor: Vector(0.7, 0.8, 0.9) -> 32Bit RGB: 0.447988420725 0.603827357292 0.7874122262
          Testcolor: Vector(0.99,0.999, 1) -> 32Bit RGB: 0.977401912212 0.997726678848 1.0
          This has a strange dynamic and I can't tell how to convert my values back so I can compare them.
          My Questions:
          What type of (RGB) values gives me the 32Bit Pixel`
          How do I convert them to a format similar to the editor RGB Values which seem to be floats in percentage with 5 digits e.g "45.123%" ?
          Cinema R13 Studio
          kind regards
          mogh
