    right click in dialog
    2 Posts 0 Posters 442 Views
      On 21/12/2013 at 07:37, xxxxxxxx wrote:
      Hey
      Is it possible to get the right click in a dialog and replace the default menu with an own or an function ?
      I try the this without success
      def Command(self, id_, msg) :
              print msg[c4d.BFM_ACTION_DP_MENUCLICK]
        On 25/12/2013 at 09:30, xxxxxxxx wrote:
        Hi, Command(...) is called for gadgets. For everything else take a look at Message(...).
        from c4d import gui
        class MyDialog(c4d.gui.GeDialog) :
            def Message(self, msg, result) :
                if msg.GetId() == c4d.BFM_INPUT:
                     if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSERIGHT:
                         # put in your code which will be executed on right mouse click
                         menu = c4d.BaseContainer()
                         menu.SetString(1000, 'Item 1')
                         menu.SetString(1001, 'Item 2')
                         menu.SetString(0, "")                # Append separator
                         menu.SetString(1003, 'Item 2')
                         result = c4d.gui.ShowPopupDialog(cd=None, bc=menu, x=c4d.MOUSEPOS, y=c4d.MOUSEPOS)
                         return True # don't route message to window parents
                return c4d.gui.GeDialog.Message(self, msg, msg)
        Cheers, s_rath
