    Keep changes for clones
    Scheduled Pinned Locked Moved PYTHON Development
    6 Posts 0 Posters 889 Views
    • H Offline
      Helper
      On 15/11/2012 at 00:04, xxxxxxxx wrote:
      Just tinkering - I know this isnt correct - but any feedback appreciated
      Trying to get a random sort mograph clones
      by shuffling the clone array
      I can randomise or reverse on a particular frame
      but not keep the randomisation
      if (frame >= 70) :  random.shuffle(marr)
      constantly shuffles - not wanted
      if (frame == 70) :  random.shuffle(marr)
      shuffles on that one frame then resets to original order on 71 - not wanted
      any ideas
      from c4d.modules import  mograph as mo
      import  math, random
      def main() :
          md = mo.GeGetMoData(op)
          if md==None: return False
          cnt = md.GetCount()
          marr = md.GetArray(c4d.MODATA_MATRIX)
          fall = md.GetFalloffs()
          #marr.reverse() #just reverse
          #marr.append(marr.pop(0))    #another reverse
          frame = doc.GetTime().GetFrame(doc.GetFps())
          for i in reversed(xrange(0, cnt)) :
              marr _.off = marr _.off__
       _ _        #if (i == 4) :  marr.reverse() # experimen__
       _ _    md.SetArray(c4d.MODATA_MATRIX, marr, True)__
       _ _    return True__
       __
       _ _
      __
      • H Offline
        Helper
        On 15/11/2012 at 12:51, xxxxxxxx wrote:
        try this ---->
         _import c4d
        import  math, random
        def my_shuffle(array) :
              random.shuffle(array)
              return array
        def main() :
          cnt = md.GetCount()
          global marr1
          try:
              marr = marr1
          except NameError:
              pass
          if (frame == 20) :
              marr1 = my_shuffle(marr)
              marr[i].off = marr[i].off
          return True ___
         _ ___
        • H Offline
          Helper
          On 15/11/2012 at 13:07, xxxxxxxx wrote:
          Brilliant - thanks douwe
          changed third to last line
          marr (square bracket)i (square bracket).off _  = marr ._ (square bracket) _ i_ (square bracket).off
          • H Offline
            Helper
            On 15/11/2012 at 16:17, xxxxxxxx wrote:
            Ye, bad things happen when one forgets to use the correct BBcode. fixed.
            Glad to help you out,
            although it feels like cheating every time i resort to the NameError trick.
            • H Offline
              Helper
              On 16/11/2012 at 03:52, xxxxxxxx wrote:
              Yup same post as you spotted douwe
              I started with the thought about shuffling the array - but then I got stuck on the code
              Will post the whole thing back there included scene file (as we can't do that here)
              The only issue I've found (I guess its to do with the global setting) if you change clone numbers or setup then you have to recompile
              http://www.c4dcafe.com/ipb/topic/72221-change-the-order-of-clones-in-a-grid/page\__gopid\__521195#entry521195
              • H Offline
                Helper
                On 19/11/2012 at 04:58, xxxxxxxx wrote:
                Anyone have any suggestions of how to get over having to reset the effector,
                every time the clone count and or type gets changed?
