    How to write GeDynamicArrayCallback
    9 Posts 0 Posters 912 Views
      On 30/05/2012 at 13:25, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Can anyone show me an example of how to write a GeDynamicArrayCallback?
      I'd like to use the DoToAll() function on a dynamic array. But I don't know how to write the CallBack it's asking for.
          int arrsize = 3;                          //Size of the array to make
        GeDynamicArray<LONG>myarray(arrsize);     //Create the new array
        myarray[0] = 100;                         //Assign some data to an element
        myarray[1] = 200;                         //Assign some data to an element
        myarray[2] = 300;                         //Assign some data to an element
        myarray.DoToAll();      //<---How do I write this function?
      ScottA
        On 30/05/2012 at 22:39, xxxxxxxx wrote:
        You need to define a method with the same characteristics as the GeDynamicArrayCallback typedef and point to it in the argument of DoToAll() (just put an ampersand in front of the method name).  It looks like void* data is the GeDynamicArray that you want to operate on (myarray) and is passed from DoToAll() to your GeDynamicArrayCallback() method in the third argument.
        I've never tried it so see if that works.
          On 31/05/2012 at 07:59, xxxxxxxx wrote:
          I've been trying to do that. But I'm having no luck.
          I've been searching the internet trying to find an example of a CallBack that looks similar to how Maxon is using it here. But haven't found one yet. 😢
          Maybe this is just because I'm new to C++.
          But to me it seems like Maxon is using every type of old, and often obscure coding methods, that ever existed in C++.
          On one hand it's frustrating as hell trying to figure out all these obscure ways of doing things.
          On the other hand. It will help me become a much better C++ coder if I eventually get the answers.
          The C4D C++ SDK would probably be a good final exam for C++ students. 😉
            On 31/05/2012 at 08:22, xxxxxxxx wrote:
            Understandable.  🙂  Maxon has only recently started to update their API to be more inline with modern C++ standards and their API has many vague features with no examples or detailed explanations.
            Have you tried declaring the callback method like:
            GeDynamicaArrayCallback mygdacbmethod(VLONG index, `Type`[URL-REMOVED]* value, void* data)
            Not sure if the method requires a return type. By default, if none is specified then C++ defaults to int as the return type which looks to be the case.
            Declare your method globally in the same .cpp file where you call DoToAll() and, most importantly, above it in the source.  C++ has two ways to recognize methods - by definition in a header or by order in the source file.  So, adding the method before it is called (in a linear fashion from top to bottom of source file) makes it known to the compiler.  Strange, but that is the way C/C++ (and some other languages) work.
            If none of this helps, I really hope that Maxon developer support can provide some answers.  Maybe I will have a chance to test this myself and respond with my results.
            Keep pounding at it and best of luck!
              On 31/05/2012 at 09:08, xxxxxxxx wrote:
              Here's the plugin with all the guts removed from it to show how I'm trying to implement the callback
              #includes
              class myDialog : public GeDialog
               private:
                   myDialog* dlg;
                   myDialog(void);
                   ~myDialog(void);
                   virtual Bool InitValues(void);
                   virtual Bool Command(LONG id,const BaseContainer &msg);
              myDialog::myDialog(void)
              myDialog::~myDialog(void)
                GeFree(dlg);
              // **This is the callback that I can't figure out how to write**
              Bool myArrayCallback(LONG index, Type &DoToAll, void *data) //<--This is wrong
                LONG ai = index;         //The array's index <--This is probably wrong too
              Bool myDialog::Command(LONG id,const BaseContainer &msg)
                myarray.DoToAll(  ?  ) //<--The function that I have no idea how to write
              Bool RegistermyResDialog(void)
                String Help = "C++ Dialog";
                return RegisterCommandPlugin(IDS_RESDIALOG, "C++ Dialog", 0, AutoBitmap("icon.tif"),Help, gNew myResDialog);
              I think I'm using the proper framework.
              But I'm obviously not writing the callback properly.
                On 31/05/2012 at 10:13, xxxxxxxx wrote:
                #includes
                  private:
                      myDialog* dlg;
                      myDialog(void);
                      ~myDialog(void);
                  GeFree(dlg);
                //This is the callback that I can't figure out how to write
                GeDynamicArrayCallback myArrayCallback(VLONG index, Type &DoToAll, void *data) //<--This is wrong
                   // You're doing to 'all' so the index parameter will be the index of the current element, I would suppose!
                   GeDynamicArray* gda = static_cast<GeDynamicArray*>(data);
                  // Do your thing to the array member (?)
                  data[index] = blah, blah
                  myarray.DoToAll(&myArrayCallback, myarray) //<--The function that I have no idea how to write
                Now, my problem is what to do inside of the callback method.  It may be passed the current index being operated on (for DoToAll(), it should be every element available in the array in sequence), but I'm not sure.  You will need to figure out how to cast the void* data to the correct type and then index it using VLONG index and do the operation I would think.  Maybe try to follow the default procedures for GeDynamicArray in accessing the members casting it to GeDynamicArray.  At least that might get you moving forward.
                  On 31/05/2012 at 10:54, xxxxxxxx wrote:
                  Thanks Robert.
                  Getting lots of errors in the CallBack function with that. So I tried it this way:
                  typedef ge_dynamicarray;
                  ge_dynamicarray myArrayCallback(VLONG index, Type &DoToAll, void *data) //<--Type undefined error
                     ge_dynamicarray* gda = static_cast<ge_dynamicarray*>(data);
                    data[index] = blah, blah;  //<---Error: data must be an expression to a complete object
                  This got rid of some of the errors. But not all of them.
                  Don't waste any more time on this Robert.
                  If you knew the answer that's one thing. But I'm taking up too much of your time with this.
                  And you're making me feel bad.
                  @MAXON - It appears that this could be documented better. Please consider this when updating the docs.
                    On 01/06/2012 at 00:14, xxxxxxxx wrote:
                    Yes, it's not well documented.
                    GeDynamicArrayCallback is declared as:
                    typedef void	GeDynamicArrayCallback(VLONG index, TYPE *value, void *data);
                    It's a void function taking (VLONG index, TYPE *value, void *data) as parameters.
                    Also don't forget it operates on a template class (GeDynamicArray<LONG>).
                    So here's how to get GeDynamicArray::DoToAll() working:
                    template<class TYPE> void myArrayCallback(VLONG index, TYPE *value, void *data)
                        // value is the current value at index in the dynamic array
                        *value *= 2;
                    GeDynamicArray<LONG> myarray(3);
                    myarray[0] = 100;
                    myarray[1] = 200;
                    myarray[2] = 300;
                    myarray.DoToAll(&myArrayCallback, NULL);
                      On 01/06/2012 at 07:51, xxxxxxxx wrote:
                      Great!
                      Thanks Yannick. 🍺
