    GeUserArea Question
    13 Posts 0 Posters 1.6k Views
    • H Offline
      Helper
      On 11/05/2012 at 09:32, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:   Windows  ; Mac  ;
      I would like to create a user interface that allows users to click on an image in a dialogue and that will then select items in the scene.  Similar to visual Selector..    Is this something I achieve using the GeUserArea class?  You can either answer with yes or no or elaborate,  lol  I am happy with either.  😄
      Thanks,
      Shawn
      • H Offline
        Helper
        On 11/05/2012 at 09:41, xxxxxxxx wrote:
        yes that's it. 😉
        i can give you some py for rederence later .
        cheers,
        • H Offline
          Helper
          On 11/05/2012 at 09:47, xxxxxxxx wrote:
          Thanks Niklas,   I will look in to it.  🙂
          ~Shawn
          • H Offline
            Helper
            On 11/05/2012 at 21:03, xxxxxxxx wrote:
            Can GeUserArea only be used in a dialog or can it be added to the attributes manager?
            Thanks,
            Shawn
            • H Offline
              Helper
              On 11/05/2012 at 23:55, xxxxxxxx wrote:
              I don't think so, but afaik you can subclass a CustomGui, can't you? CustomGui's can be added in both.
              PS: Here ya go, ready for the script-manager, you only have to add some paths to your icons you want to show.
              class BaseElement(object) :
                def __init__(self) :
                    self.last_region = 0, 0, 0, 0
                def __contains__(self, (x, y)) :
                    x1, y1, x2, y2 = self.last_region
                    return (x1 <= x <= x2 and y1 <= y <= y2)
                def render(self, area, x, y) :
                    pass
              class BitmapElement(BaseElement) :
                def __init__(self, id, bmp, x, y) :
                    super(BitmapElement, self).__init__()
                    self.id  = id
                    self.bmp = bmp
                    self.x   = x
                    self.y   = y
                def render(self, area, x=0, y=0) :
                    x += self.x
                    y += self.y
                    w, h = self.bmp.GetSize()
                    self.last_region = (x, y, x + w, y + h)
                    area.DrawBitmap(self.bmp, x, y, w, h,
                                    0, 0, w, h, c4d.BMP_NORMAL)
              class BitmapGroup(BaseElement) :
                COLOR_BG = c4d.Vector(0.21, 0.19, 0.27)
                def __init__(self, x, y, w, h) :
                    super(BitmapGroup, self).__init__()
                    self.x    = x
                    self.y    = y
                    self.w    = w
                    self.h    = h
                    self.bmps = []
                def add_bitmap(self, bmp) :
                    self.bmps.append(bmp)
                    x += self.x
                    y += self.y
                    w  = self.w
                    h  = self.h
                    area.SetClippingRegion(self.x, self.y, self.x + w, self.y + h)
                    if self.COLOR_BG:
                        area.DrawSetPen(self.COLOR_BG)
                        area.DrawRectangle(x, y, x + w, y + h)
                    for bmp in self.bmps:
                        bmp.render(area, x, y)
                    area.ClearClippingRegion()
                def what_bitmap(self, x, y) :
                    if (x, y) not in self:
                    hit_bmp = None
                        if (x, y) in bmp:
                            hit_bmp = bmp
                    return hit_bmp
              class UserArea(c4d.gui.GeUserArea) :
                COLOR_BG = c4d.Vector(.21)
                    self.bmpgroup = BitmapGroup(0, 0, 0, 0)
                def GetMinSize(self) :
                    return (100, 80)
                def DrawMsg(self, x1, y1, x2, y2, msg) :
                    self.DrawSetPen(self.COLOR_BG)
                    self.DrawRectangle(x1, y1, x2, y2)
                    # adapt size of the bmpgroup
                    self.bmpgroup.x = x1
                    self.bmpgroup.y = y1
                    self.bmpgroup.w = x2 - x1
                    self.bmpgroup.h = y2 - y1
                    self.bmpgroup.render(self, x1, y1)
                def InputEvent(self, msg) :
                    if msg[c4d.BFM_INPUT_DEVICE] == c4d.BFM_INPUT_MOUSE:
                        x, y = msg[c4d.BFM_INPUT_X], msg[c4d.BFM_INPUT_Y]
                        g2l  = self.Global2Local()
                        x += g2l['x']
                        y += g2l['y']
                        if msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSELEFT:
                            bmp = self.bmpgroup.what_bitmap(x, y)
                            if bmp:
                                self.bitmap_clicked(bmp, bmp.id)
                # new
                def bitmap_clicked(self, bmp, id) :
                    # TODO: implement what happens when Bitmap is clicked
                    print "Bitmap with id", id, "was clicked!"
                    pass
              class Dialog(c4d.gui.GeDialog) :
                def __init__(self, ua) :
                    self.ua = ua
                def CreateLayout(self) :
                    self.AddUserArea(1000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
                    self.AttachUserArea(self.ua, 1000)
              def main() :
                ua = UserArea()
                dlg = Dialog(ua)
                # Add bitmaps to the BitmapGroup with an offset of 50 pixels
                paths = []      # add your icons or whatever here
                for i, path in enumerate(paths) :
                    bmp = c4d.bitmaps.BaseBitmap()
                    bmp.InitWith(path)
                    bmp = BitmapElement(i, bmp, i * 50, 0)
                    ua.bmpgroup.add_bitmap(bmp)
                dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE)
              • H Offline
                Helper
                On 13/05/2012 at 12:53, xxxxxxxx wrote:
                Some response would be quite nice. Those code-snippets don't just fly through the window after calling my big-friend Coding God.
                • H Offline
                  Helper
                  On 13/05/2012 at 13:00, xxxxxxxx wrote:
                  Lol sorry niklas. I hadn't had a chance to look at them yet. Thank you for giving me the examples. To be honest I didn't even know there was a code example because I had checked it on my phone and the email that was sent to me didn't have an example.   Sorry for the lack of response.   Thanks again.   I do appreciate your assistance.
                  -Shawn
                  • H Offline
                    Helper
                    On 14/05/2012 at 05:10, xxxxxxxx wrote:
                    So I have to excuse in return. I assumed you did already see it as you have opened another Thread at that time.
                    Best,
                    Niklas
                    • H Offline
                      Helper
                      On 14/05/2012 at 05:15, xxxxxxxx wrote:
                      Thanks again Niklas,
                      Your code has been most helpful.  🙂
                      ~Shawn
                      • H Offline
                        Helper
                        On 14/08/2014 at 08:14, xxxxxxxx wrote:
                        Niklas - the code you posted above, is brilliant, and i have a question:
                        Is it possible to use GeUserArea similar to the above ( ie clickable bitmaps ) but in the ObjectManager properties for a Plugin?
                        I thought itd be quicker to ask before i waste a lot of time trying something out that isnt possible!
                        • H Offline
                          Helper
                          On 14/08/2014 at 08:55, xxxxxxxx wrote:
                          I might just use the BITMAPBUTTON description element, but would be useful to know..  Plus it avoids registering icon id`s..
                          • H Offline
                            Helper
                            On 14/08/2014 at 10:29, xxxxxxxx wrote:
                            Hi Eclectrik,
                            Not from Python, unfortunately. That would require implementing a CustomGui plugin.
                            Best,
                            -Niklas
                            PS: Wonder why I was so harsh back then, sorry for that.
                            • H Offline
                              Helper
                              On 14/08/2014 at 11:15, xxxxxxxx wrote:
                              Hi Niklas - sorry i forgot to mention in this case i am using C++.
                              BTW - i would also be annoyed if i posted a whole script for somebody and didn't get any thanks for it!
