    Document Project Settings
    5 Posts 0 Posters 773 Views
    • H Offline
      Helper
      On 09/06/2011 at 09:58, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Platform:   Windows  ;
      Here is the list of all the project settings so users can quickly look them up if needed:
      //Reference files:
      //DOCUMENTSETTINGS_GENERAL:General settings: See ddoc.h.
      //DOCUMENTSETTINGS_MODELING:Modeler settings: See MDATA_Options and toolsnapping.h.
      //DOCUMENTSETTINGS_TOOLS: See Tool settings
      //// Scene Scale & Units optoptions
      BaseContainer *bc = doc->GetSettingsInstance(DOCUMENTSETTINGS_DOCUMENT);
      UnitScaleData *usd = (UnitScaleData* )bc->GetCustomDataType(DOCUMENT_DOCUNIT, CUSTOMDATATYPE_UNITSCALE);
      if (!usd) return FALSE;
      usd->SetUnitScale(1.0, DOCUMENT_UNIT_CM);// SceneScale & Units options = DOCUMENT_UNIT_UNDEF, DOCUMENT_UNIT_KM, DOCUMENT_UNIT_M, DOCUMENT_UNIT_CM,
                                             //DOCUMENT_UNIT_MM, DOCUMENT_UNIT_MICRO, DOCUMENT_UNIT_MILE, DOCUMENT_UNIT_YARD,DOCUMENT_UNIT_FOOT, DOCUMENT_UNIT_INCH
      bc->SetData(DOCUMENT_DOCUNIT, GeData(CUSTOMDATATYPE_UNITSCALE, *usd));
      doc->Message(MSG_UPDATE);
      EventAdd();
      //// Project Settings
      //First set up BaseTime so we can use it later on in the attributes
      BaseTime time = doc->GetTime(); // assigns the basetime class to a variable
      Real fps = doc->GetFps();       // Gets the frames per second value
      Real frame = time.GetFrame(fps);// The current frame the slider is on
      doc->SetParameter(DOCUMENT_FPS, GeData(30), DESCFLAGS_SET_0);               // Sets the FPS attribute
      doc->SetParameter(DOCUMENT_TIME, GeData(BaseTime(0, fps)), DESCFLAGS_SET_0); // The frame where the scrubber starts
      doc->SetParameter(DOCUMENT_MINTIME, GeData(BaseTime(0, fps)), DESCFLAGS_SET_0);//The start frame value
      doc->SetParameter(DOCUMENT_MAXTIME, GeData(BaseTime(90, fps)), DESCFLAGS_SET_0);//The end Frame value
      doc->SetParameter(DOCUMENT_LOOPMINTIME, GeData(BaseTime(0, fps)), DESCFLAGS_SET_0);//The Preview option Start time
      doc->SetParameter(DOCUMENT_LOOPMAXTIME, GeData(BaseTime(90, fps)), DESCFLAGS_SET_0);//The Preview option End time
      doc->SetParameter(DOCUMENT_LOD, GeData(1.0), DESCFLAGS_SET_0);            // Level of Detail
      doc->SetParameter(DOCUMENT_RENDERLOD, GeData(FALSE), DESCFLAGS_SET_0);    // Render LOD in Editor
      doc->SetParameter(DOCUMENT_USEANIMATION, GeData(TRUE), DESCFLAGS_SET_0);  // Use Animation
      doc->SetParameter(DOCUMENT_USEEXPRESSIONS, GeData(TRUE), DESCFLAGS_SET_0);// Use Expressions
      doc->SetParameter(DOCUMENT_USEGENERATORS, GeData(TRUE), DESCFLAGS_SET_0); // Use Generators
      doc->SetParameter(DOCUMENT_USEDEFORMERS, GeData(TRUE), DESCFLAGS_SET_0);  // Use Deformers
      doc->SetParameter(DOCUMENT_USEMOTIONSYSTEM, GeData(TRUE), DESCFLAGS_SET_0); // Use Motion System
      doc->SetParameter(DOCUMENT_DEFAULTMATERIAL_TYPE, GeData(1), DESCFLAGS_SET_0);// 0=WHITE, 1=GREY-BLUE, 2=USER
      doc->SetParameter(DOCUMENT_CLIPPING_PRESET, GeData(1), DESCFLAGS_SET_0); // 3=TINY, 0=SMALL, 1=MEDIUM, 2=LARGE, 4=HUGE, 5=CUSTOM
      doc->SetParameter(DOCUMENT_CLIPPING_PRESET_NEAR, GeData(1.0), DESCFLAGS_SET_0); //Sets the Near clipping value
      doc->SetParameter(DOCUMENT_CLIPPING_PRESET_FAR, GeData(100000.0), DESCFLAGS_SET_0); //Sets the Far clipping value
      doc->SetParameter(DOCUMENT_LINEARWORKFLOW, GeData(TRUE), DESCFLAGS_SET_0); // Use Linear Workflow
      doc->SetParameter(DOCUMENT_COLORPROFILE, GeData(1), DESCFLAGS_SET_0);//  0=SRGB, 1=LINEAR, 2=DISABLED;
      EventAdd();
      ///// Info Settings
      doc->SetParameter(DOCUMENT_INFO_AUTHOR, GeData(""), DESCFLAGS_SET_0);    //Type your name in here
      doc->SetParameter(DOCUMENT_INFO_COPYRIGHT, GeData(""), DESCFLAGS_SET_0); //Type your copyright info here
      doc->SetParameter(DOCUMENT_INFO_README, GeData(""), DESCFLAGS_SET_0);   // Type your notes here
      EventAdd();
      //// Dynamics Settings
      //Make sure to use this include:
      #include "../../modules/dynamics2/res/description/dynworldobject.h"
       //GENERAL
      BaseSceneHook *sh = doc->FindSceneHook(180000100);
      if (!sh) return FALSE;
      sh->SetParameter(DescID(WORLD_ENABLED), GeData(TRUE), DESCFLAGS_SET_0);            // Enabled
      sh->SetParameter(DescID(WORLD_DISABLE_DURING_LEAP), GeData(TRUE), DESCFLAGS_SET_0);// Disable on Skip Frame
      sh->SetParameter(DescID(WORLD_TIMESCALE), GeData(BaseTime(0, fps)), DESCFLAGS_SET_0);// Time Scale
      sh->SetParameter(DescID(WORLD_GRAVITY), GeData(1000.0), DESCFLAGS_SET_0);          // Gravity value
      sh->SetParameter(DescID(WORLD_DENSITY), GeData(1.0), DESCFLAGS_SET_0);             // Density value
      EventAdd();
       //CACHE
      sh->SetParameter(DescID(WORLD_CACHE_BAKE), GeData(1.0), DESCFLAGS_SET_0);                    //...See Button code below
      sh->SetParameter(DescID(WORLD_CACHE_CLEAR), GeData(1.0), DESCFLAGS_SET_0);                   //...See Button code below
      sh->SetParameter(DescID(WORLD_CACHE_USE), GeData(FALSE), DESCFLAGS_SET_0);                   //Use cached data
      sh->SetParameter(DescID(WORLD_CACHE_DISABLE_BAKED_OBJECTS), GeData(FALSE), DESCFLAGS_SET_0); //Disable cached objects
      sh->SetParameter(DescID(WORLD_CACHE_USE_TIME), GeData(FALSE), DESCFLAGS_SET_0);              //Use time stops to control cached playback
      sh->SetParameter(DescID(WORLD_CACHE_TIME), GeData(BaseTime(0, fps)), DESCFLAGS_SET_0);       //time stops frame value
      EventAdd();
       //EXPERT
      sh->SetParameter(DescID(WORLD_MARGIN), GeData(1.0), DESCFLAGS_SET_0);                        //Collision Margin
      sh->SetParameter(DescID(WORLD_SCALE), GeData(1.0), DESCFLAGS_SET_0);                        // Scale
      sh->SetParameter(DescID(WORLD_CONTACT_RESTITUTION_LIFETIME), GeData(5.0), DESCFLAGS_SET_0); // Resting Contact
      sh->SetParameter(DescID(WORLD_SEED), GeData(0.0), DESCFLAGS_SET_0);                         // Random Seed
      sh->SetParameter(DescID(WORLD_SUBSTEPS), GeData(5.0), DESCFLAGS_SET_0);                     // Steps per frame
      sh->SetParameter(DescID(WORLD_ITERATIONS), GeData(10.0), DESCFLAGS_SET_0);                  // Max Iterations per step
      sh->SetParameter(DescID(WORLD_ERROR_THRESHOLD), GeData(10.0), DESCFLAGS_SET_0);             // Error threshold
      EventAdd();
       //VISUALIZATION
      sh->SetParameter(DescID(WORLD_VISUALIZE), GeData(FALSE), DESCFLAGS_SET_0);               // Enable
      sh->SetParameter(DescID(WORLD_VISUALIZE_SHAPES), GeData(TRUE), DESCFLAGS_SET_0);         // Collision Shapes
      sh->SetParameter(DescID(WORLD_VISUALIZE_AABBS), GeData(TRUE), DESCFLAGS_SET_0);          // Bounding Boxes
      sh->SetParameter(DescID(WORLD_VISUALIZE_CONTACT_POINTS), GeData(TRUE), DESCFLAGS_SET_0); // Contact Points
      sh->SetParameter(DescID(WORLD_VISUALIZE_CONSTRAINTS), GeData(TRUE), DESCFLAGS_SET_0);    // Connectors
      EventAdd();
      // Execute Dynamics Cache Button
      BaseContainer msg(BFM_ACTION);
      msg.SetLong(BFM_ACTION_ID, 1440);
      msg.SetLong(BFM_ACTION_VALUE, TRUE);
      DescriptionCommand dc;
      dc.id = DescID(DescLevel(WORLD_CACHE_BAKE, DTYPE_BUTTON, sh->GetType()));
      DescriptionCheckUpdate du;
      du.doc = doc;
      du.descid = &dc.id;
      du.drawflags = 0;
      sh->Message(MSG_DESCRIPTION_COMMAND, (void* )&dc);
      sh->Message(MSG_DESCRIPTION_CHECKUPDATE, (void* )&du);
      EventAdd();
      // Execute Dynamics Clear Cache Button
      dc.id = DescID(DescLevel(WORLD_CACHE_CLEAR, DTYPE_BUTTON, sh->GetType()));
      du.doc = doc;
      du.descid = &dc.id;
      du.drawflags = 0;
      EventAdd();
      • H Offline
        Helper
        On 09/06/2011 at 13:14, xxxxxxxx wrote:
        Originally posted by xxxxxxxx
        But I'm having trouble with the document scale & Unit's attributes.
        If someone can tell me how to edit those settings.
        Since R12 CINEMA supports true units which required each document to have a unit scale. Its data type is UnitScaleData. Please check the docs for a detailed description.
        cheers,
        Matthias
        • H Offline
          Helper
          On 09/06/2011 at 16:43, xxxxxxxx wrote:
          The SDK does a good job explaining the methods and their parameters.
          But it assumes that the reader knows how to construct the correct path to the proper owner of these methods(in this case the document).
          Here's my crude attempt:
          #include "customgui_unitscale.h"
            UnitScaleData *data;
            data->SetUnitScale(1, DOCUMENT_UNIT_KM);
            doc->SetParameter(DescID(DOCUMENT_DOCUNIT), GeData(data), DESCFLAGS_SET_0); //<--This is definitely wrong
          I'm still not very good at understanding the SDK yet.
          I'm hoping if I get enough examples under my belt. I will get to a point where I can use it much better.
          • H Offline
            Helper
            On 10/06/2011 at 02:08, xxxxxxxx wrote:
            You can set custom data like this:
            usd->SetUnitScale(10.0, DOCUMENT_UNIT_KM);
            EventAdd();
            cheers,
            Matthias
            • H Offline
              Helper
              On 10/06/2011 at 07:25, xxxxxxxx wrote:
              Thank you sir.🍺
              I added it to the list. Now it should be complete.
