    Py4d: Xpresso Node User Data Output Port
    4 Posts 0 Posters 980 Views
    • H Offline
      Helper
      On 18/09/2010 at 07:06, xxxxxxxx wrote:
      Cinema 4D Version:   12.021
      Platform:      Mac OSX  ;
      Language(s) :       PYTHON  ;
      My first post here 😉
      Problem: when I use Python to set up a userdata output port on an xpresso node on the active object, it turns yellow and won't work, yet when I drag the same object into the xpresso tag setup and set the output port to the userdata it looks and works as expected. Seems to be just the userdata output port that is the problem, as other output ports work fine when set using Python.
      I suspect that I am not making an internal connection somewhere--or that it possibly is broken.
      Any ideas?
      Here's the Python code I am using:
      def main() :
          ActObj = doc.GetActiveObject()
      Make the user data boole button on active object
      bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL) #create default container
          bc[c4d.DESC_NAME] = "Pucker"                        #rename the entry
      Pucker = ActObj.AddUserData(bc)           #add userdata  and set to container
          ActObj[Pucker] = False                          #assign a value
      #c4d.EventAdd()                                   #update
      Create the xPresso tag on the active object
      xtag = c4d.BaseTag(c4d.Texpresso)
          if ActObj is not None: #check if there is no object
              ActObj.InsertTag(xtag)
      tag = op.GetFirstTag() # returns the first tag of the object
          nodemaster = tag.GetNodeMaster()
      Generate node with port
      nodeObjOut = nodemaster.CreateNode(nodemaster.GetRoot(), c4d.ID_OPERATOR_OBJECT, insert=None, x=250, y=200)
      nodeObjOut.AddPort(c4d.GV_PORT_OUTPUT, [c4d.ID_USERDATA, 1])
      nodemaster.Message(c4d.MSG_UPDATE) #send update to nodemaster
          c4d.EventAdd() #set an event to c4d core to update (never use in an expression)
      • H Offline
        Helper
        On 19/09/2010 at 12:10, xxxxxxxx wrote:
        Hi ernia,
        for user data you need to specify some additional IDs. I also recommend to inform the node about the new port by setting "message=True".
        USERDATA_NUMERO = 1 #change this
        nodeObjOut.AddPort(c4d.GV_PORT_OUTPUT, c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER, 0), c4d.DescLevel(USERDATA_NUMERO)), message=True)
        For custom datatypes like gradient, splinedata, ... you should define their type as well ( c4d.DescLevel(USERDATA_NUMERO, c4d.DTYPE_GRADIENT, 0) )
        Cheers, Sebastian
        • H Offline
          Helper
          On 19/09/2010 at 13:31, xxxxxxxx wrote:
          Thanks Sebastian.
          Not sure what it all means but it's working fine now.
          Arik
          • H Offline
            Helper
            On 28/03/2013 at 07:54, xxxxxxxx wrote:
            Wow, I've been looking for AddPort for Userdata for ages!
            Sebastian, is it documented somewhere? Is there a way I could get there by myself?
