    Reading texture data
    3 Posts 0 Posters 581 Views
      On 15/06/2010 at 00:43, xxxxxxxx wrote:
      Cinema 4D Version:   11.5
      i like to read the size of an texture from a material which assigned to an base object.
      I do this with the PluginShader.
      PluginShader *shd = (PluginShader* )matdata->GetLink(MATERIAL_COLOR_SHADER, GetActiveDocument() , Xbitmap);
      BaseBitmap *pbb = shd->GetBitmap();
      if (pbb) {
          lx = pbb->GetBw();
          ly = pbb->GetBh();
      But i get always an NULL pointer for the base bitmap??
      Has someone an idea?
        On 15/06/2010 at 01:08, xxxxxxxx wrote:
        You have to make sure to call GetBitmap() within a pair of InitRender()/FreeRender() calls. If there is no InitRenderStruct avaible you can create a dummy structure on the stack.
        here an example:
        Bool MenuTest::Execute(BaseDocument *doc)
          BaseMaterial *mat = doc->GetActiveMaterial();
          if (!mat) return FALSE;
          BaseContainer *data = mat->GetDataInstance();
          PluginShader *shd = (PluginShader* )data->GetLink(MATERIAL_COLOR_SHADER, doc, Xbitmap);
          if (!shd) return FALSE;
          InitRenderStruct is;
          is.version = GetC4DVersion();
          is.time = doc->GetTime();
          is.fps = doc->GetFps();
          Filename docpath = doc->GetDocumentPath();
          is.docpath = &docpath;
          String matname = mat->GetName();
          is.matname = &matname;
          is.errorlist = NULL;
          is.vd = NULL;
          is.doc = doc;
          is.thread = NULL;
          is.flags = INITRENDERFLAG_TEXTURES;
          shd->InitRender(&is);
          BaseBitmap *bmp = shd->GetBitmap();
          if (!bmp) return FALSE;
          GePrint(LongToString(bmp->GetBw()));
          GePrint(LongToString(bmp->GetBh()));
          shd->FreeRender();
          On 15/06/2010 at 01:35, xxxxxxxx wrote:
          i see, create it works
          thanks a lot
