    TARGETEXPRESSIONTAG_LINK??
    11 Posts 0 Posters 1.1k Views
    • H Offline
      Helper
      On 08/10/2009 at 12:49, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Platform:   Windows  ;
      Hi there,
      i am struggling with the following code. I found that old thread by kuroyume and updated my code accordingly, but the link field still stays empty.
      anyone?
      thanks for any help.
      cheers,
      ello
      first:
      \>  BaseTag *tempTag = clone->MakeTag(Ttargetexpression);
      \>  tempTag->GetDataInstance()->SetLink(TARGETEXPRESSIONTAG_LINK,target);
      second:
      \>  AutoAlloc<BaseLink> link;
      \>  link->SetLink(target);
      \>  tempTag->SetParameter(DescID(TARGETEXPRESSIONTAG_LINK), GeData(link), NULL);
      • H Offline
        Helper
        On 08/10/2009 at 13:48, xxxxxxxx wrote:
        First try is correct. You need to send after: tempTag->Message(MSG_UPDATE);
        And, of course, the 'target' MUST be in a document. You can't set links to things not inserted into a document.
        • H Offline
          Helper
          On 08/10/2009 at 13:57, xxxxxxxx wrote:
          hm, that doesnt change anything. the "target" is created by the plugin earlier. maybe thats the problem?
          \>       BaseObject* target = NULL;
          \>       target = BaseObject::Alloc(Onull);
          \>       target->SetPos(targetHelper->GetPos());
          \>       target->GetDataInstance()->SetLong(NULLOBJECT_DISPLAY,NULLOBJECT_DISPLAY_POINT);
          \>       target->GetDataInstance()->SetLong(NULLOBJECT_RADIUS,20);
          \>       target->InsertUnderLast(main);
          anything else could be responsible??
          • H Offline
            Helper
            On 08/10/2009 at 16:45, xxxxxxxx wrote:
            I still can't recreate your problem. This code was substituted quickly into one of my existing Command plugins and works:
            >      BaseObject\* target =     BaseObject::Alloc(Onull); \>      if (!target)               return FALSE; \>      doc->InsertObject(target, NULL, NULL, FALSE); \>      target->SetPos(Vector(100.0f)); \>      BaseContainer\*     bc =     target->GetDataInstance(); \>      bc->SetLong(NULLOBJECT_DISPLAY,     NULLOBJECT_DISPLAY_POINT); \>      bc->SetReal(NULLOBJECT_RADIUS,     20.0f); \>      //target->InsertUnderLast(main); \>      BaseObject\* source =     BaseObject::Alloc(Ocube); \>      if (!source)               return FALSE; \>      doc->InsertObject(source, NULL, NULL, FALSE); \>      BaseTag\*     tempTag =     source->MakeTag(Ttargetexpression); \>      if (!tempTag)               return FALSE; \>      tempTag->GetDataInstance()->SetLink(TARGETEXPRESSIONTAG_LINK,target); \>      EventAdd(); \>
            Note that NULLOBJECT_RADIUS is a Real not a Long value. Also note EventAdd().
            • H Offline
              Helper
              On 09/10/2009 at 02:22, xxxxxxxx wrote:
              thanks robert,
              very strange.. maybe its really because i am using it in a ObjectPlugin?? Are there any restrictions?
              i'll try to find whats the reason for this..
              edit: i just recognized that "target" is deleted when i convert the pluginobject ("c")
              its visible as long the plugin object exists, so maybe its somehow lost.. investigating it...
              • H Offline
                Helper
                On 09/10/2009 at 02:43, xxxxxxxx wrote:
                ok, i got it partially working by placing the tag creating snippet after inserting the clone into the plugin...
                \>  clone->InsertUnderLast(main);
                \>  if (!tempTag) goto Error;
                \>            tempTag->GetDataInstance()->SetLink(TARGETEXPRESSIONTAG_LINK,(BaseList2D* )target);
                now its working when the object is converted, but not when the pluginobject is still there... any ideas??
                • H Offline
                  Helper
                  On 09/10/2009 at 05:35, xxxxxxxx wrote:
                  The problem is you are working on a virtual object which is not yet in the document. Expressions will not work.
                  cheers,
                  Matthias
                  • H Offline
                    Helper
                    On 09/10/2009 at 06:02, xxxxxxxx wrote:
                    I had a sneaking suspicion that GetVirtualObjects() might be involved here. Since it is not 'directly' added to the document that makes sense. Matthias, would it still work if the target object were a real document object?
                    • H Offline
                      Helper
                      On 09/10/2009 at 06:11, xxxxxxxx wrote:
                      It doesn't seem to work.
                      cheers,
                      Matthias
                      • H Offline
                        Helper
                        On 09/10/2009 at 11:14, xxxxxxxx wrote:
                        yes, i already had a real object in the scene to retrieve its position and use it in my plugin.
                        how can i accomplish such a thing?? i know, i could calculate the facing of the objects myself, but i really like to use a tag thats already there, since this would work even if the object is converted. anything possible??
                        cheers,
                        ello
                        • H Offline
                          Helper
                          On 09/10/2009 at 12:38, xxxxxxxx wrote:
                          ok, i solved this by calculating the facing manually in the plugin and after converting the tags are used...
                          thanks for all yoour inputs 🙂
