    Description / Grey out part of vector
    9 Posts 0 Posters 882 Views
    • H Offline
      Helper
      On 06/07/2009 at 13:39, xxxxxxxx wrote:
      Cinema 4D Version:   r11
      Platform:   Windows  ;
      Hi there,
      After i have learned how to show/hide certain parts of a description, i am wondering if there is a way to grey out the y and z component of a VECTOR description?
      or do i need to hide the VECTOR and show a LONG element?
      thanks and cheers,
      ELlo
      • H Offline
        Helper
        On 07/07/2009 at 03:54, xxxxxxxx wrote:
        You have to check for the second level in GetDEnabling(). Note that it can only work with a subchannel vector description. You can do this by adding the CUSTOMGUI SUBDESCRIPTION flag to your resource file.
        > VECTOR CIRCLEOBJECT_VECTOR { UNIT REAL; MIN 0.0; CUSTOMGUI SUBDESCRIPTION; }
        > \> Bool DoubleCircleData::GetDEnabling(GeListNode \*node, const DescID &id;,const GeData &t;\_data,LONG flags,const BaseContainer \*itemdesc) \> { \>      BaseContainer &data; = \*((BaseObject\* )node)->GetDataInstance(); \> \>      if (id[0].id == CIRCLEOBJECT_VECTOR) \>      { \>           if (id.GetDepth() > 1 && id[1].id == VECTOR_X) \>           { \>                return FALSE; \>           } \>      } \> \>      return TRUE; \> } \>
        cheers,
        Matthias
        • H Offline
          Helper
          On 07/07/2009 at 04:36, xxxxxxxx wrote:
          thank you very much!
          cheers,
          ello
          • H Offline
            Helper
            On 08/07/2009 at 09:27, xxxxxxxx wrote:
            hi there,,
            i am just wondering.. there really is no way to get this working without visually expanding the vector?
            thanks and cheers,
            ello
            • H Offline
              Helper
              On 09/07/2009 at 01:33, xxxxxxxx wrote:
              Unfortunatly not.
              cheers,
              Matthias
              • H Offline
                Helper
                On 11/07/2009 at 03:01, xxxxxxxx wrote:
                another question i came across.. how can i hide those vector components totally? i know how i can hide complete description elements, but not how to hide for example the y and z component of a vector?
                thanks in advance,
                ello
                • H Offline
                  Helper
                  On 14/07/2009 at 01:54, xxxxxxxx wrote:
                  You can't hide the subchannels of a vector description. If you want full control you have to write your own vector data type and custom gui. There is an example in the SDK examples.
                  cheers,
                  Matthias
                  • H Offline
                    Helper
                    On 14/07/2009 at 11:50, xxxxxxxx wrote:
                    i was afraid of that. since this means no previous files will work after that change (due to different description ID's).. or am i missing something?
                    cheers,
                    ello
                    • H Offline
                      Helper
                      On 14/07/2009 at 12:57, xxxxxxxx wrote:
                      a custom datatype will not result in a different resource ID. You can still use the same ID for your own data type (of course the plugin id will be different but that shouldn´t affect loading of old files). And vector values from the container can be easily converted to the new data type. Should work imo.
