    RecordKey() & Memory usage
    19 Posts 0 Posters 1.7k Views
    • H Offline
      Helper
      On 03/12/2008 at 10:26, xxxxxxxx wrote:
      Cinema 4D Version:   R10+
      Platform:   Windows  ;
      Hi folks,
      I'm trying to record keys for an animation... I have created tracks for each joint (position and rotation XYZ tracks) and am then looping through my data to create keys for each at the appropriate keyframes.
      What I'm basically doing is, for any change in position, I do a RecordKey() for X, Y and Z position tracks.  For any change in rotation, I do a RecordKey() for X, Y and Z rotation tracks (in other words, for any 'keyframe', there's either 3 or 6 new keys, for any particular joint object).
      Now, in my test case, the stats are as follows:
      • Joints: 49  (a few of them have 0 or 1 keyframes, but most have many)
      • total frames: 1680
      • total keys to be generated to include XYZtranslation/XYZrotation for all joints, at the desired frames: 189,234
      ...note that the final number above is the total number of calls to doc->RecordKey() for the test case.
      Ok, so here's the problem... If I Import this scene as .FBX, it loads fine and in fact, there are 3 copies of that skeletal strucure and as far as I can tell, there may be a 'keyframe' for _every_ joint at _every_ frame (in other words, far more keys than I'm trying to record with my plugin).
      When I try to record all the keys, I quickly/eventually run out of memory(!).  If I add a skip value and only record half the frames (or every 10th or 5th), it works fine.  I have looked over the code multiple times now and just can't find any obvious source of memory leaks, so I'm hitting a brick wall.
      Has anyone else noticed huge memory consumption with calling doc->RecordKey() ?  The actual relevent secion of code (for position keys) looks like this:
          if( (DWORD)(pKey->time) == i )
              // convert to Cinema4D Matrix
              Matrix am = Matrix( Vector(pJ->matLocal[0][3], pJ->matLocal[1][3], pJ->matLocal[2][3]),
                                        Vector(pJ->matLocal[0][0], pJ->matLocal[1][0], pJ->matLocal[2][0]),
                                        Vector(pJ->matLocal[0][1], pJ->matLocal[1][1], pJ->matLocal[2][1]),
                                        Vector(pJ->matLocal[0][2], pJ->matLocal[1][2], pJ->matLocal[2][2]));
              BaseObject *pJointObj = pJ->pJointObj;
              pJointObj->SetMl(am);
              pJointObj->Message(MSG_UPDATE);
              stime = BaseTime::BaseTime(pKey->time, m_animationFps);
              m_pBaseDoc->RecordKey(pJointObj, stime, DescID(DescLevel(ID_BASEOBJECT_POSITION,DTYPE_VECTOR,0),
                                    DescLevel(VECTOR_X,DTYPE_REAL,0)), NULL, false, false, false);
                                    DescLevel(VECTOR_Y,DTYPE_REAL,0)), NULL, false, false, false);
                                    DescLevel(VECTOR_Z,DTYPE_REAL,0)), NULL, false, false, false);
              totalkeys += 3;
              break;
      ...with similar code for the rotation keys.
      • H Offline
        Helper
        On 03/12/2008 at 11:24, xxxxxxxx wrote:
        Something just has to be wrong with this picture...
        For  38,010 total keys (skipping 4/5ths of them), I'm using a gigabyte of memory.
        For 740,880 total keys, the .FBX import is using ~75 mb (in the ball-park of 10,000 keys per mb)
        ...I must be doing something wrong.  Any help?
        • H Offline
          Helper
          On 03/12/2008 at 11:34, xxxxxxxx wrote:
          ..also, if I just comment out the RecordKey() lines, I only use ~4mb (for the tracks and mesh objects, etc., but no keys recorded), so this is something specific to RecordKey(), or the way I'm using it.
          • H Offline
            Helper
            On 04/12/2008 at 00:30, xxxxxxxx wrote:
            I added some tracking code and here are some additional stats:
            • average memory allocated per RecordKey() call - 27KB (as much as half a megabyte for just 3 keys , but there appears to be a memory pooling mechanism in place, since somtimes it's zero)
            • 3,954 translation keys uses 104.57MB
            • 34,056 rotation keys uses 917.32MB
            • 38,010 total keys uses 104MB + 917MB = 1.02GB
            ...so, I guess my question boils down to: Should RecordKey() be using an average of 27KB per call?
            I'm still baffled how the .FBX import, which is creating far more keys than I am is using far less memory.
            • H Offline
              Helper
              On 04/12/2008 at 01:10, xxxxxxxx wrote:
              Interesting... I'm playing with my skip count (skipping more frames, so fewer total keys get generated) and getting different results...
              • 24 trans @ 0bytes avg + 201 rot @ 2.62KB avg = 526.39KB total
              • **57  trans @0bytes avg **** + **  453 rot @ 3.10KB avg = 1.37MB total
              • 171  trans @ 5.13KB avg +   1515 rot @ 3.24KB avg =   5.65MB total
              • 249  trans @ 2.11KB avg +   2238 rot @ 4.31KB avg =   9.94MB total
              • 381 trans @ 3.68KB avg + 3177 rot @ 4.91KB avg =   16.62MB total
              • 765  trans @ 8.02KB avg +   6555 rot @ 7.14KB avg =   51.72MB total
              • 2004  trans @ 14.09KB avg +   16989 rot @ 15.06KB avg =   277.43MB total
              • 3954  trans @ 26.99KB avg +   34056 rot @ 27.59KB avg =   1.02GB total
              ...note that my tracking code is wrapped soley around sets of 3 calls to RecordKey(), so the averages and totals ONLY reflect memory actually used by calling that routine.   Also note the progression in average memory used per call as the number of total keys generated gets higher - from 0- 2.6KB for a couple hundred keys, up to ten times that number for 38,000+ keys.
              • H Offline
                Helper
                On 04/12/2008 at 01:49, xxxxxxxx wrote:
                Additional data-points...
                Here are numbers for "max amount allocated (pool?) to generate 3 keys" (ie. either a TransX/TransY/TransZ or RotX/RotY/RotZ set of keys)...
                • @225 keys - 175.47KB
                • @510 keys - 175.47KB
                • @1686 keys - 350.83KB
                • @2487 keys - 175.48KB (odd)
                • @3558 keys - 350.81KB
                • @7320 keys - 350.83KB
                • @18993 keys - 350.83KB
                • @20655 keys - 525.95KB
                • @23466 keys - 350.84KB (odd)
                • @26766 keys - 526.28KB
                • @31398 keys - 526.28KB
                • @38010 keys - 526.16KB
                • @47019 keys - 526.28KB (per key averages are up to ~ 33KB )
                • @62667 keys - 689.83KB (per key averages  are up to ~ 43KB )
                • @94491 keys - 868.80KB (per key averages  are up to ~ 65KB )
                ...I couldn't go any higher, because I was using 5.84GB of memory for that last reading.
                • H Offline
                  Helper
                  On 04/12/2008 at 02:01, xxxxxxxx wrote:
                  One thought (which I'll go check out)... I'm compiling this with the R10.1 SDK, but am using R10.5 to test with, which also means that the (built-in) FBX importer is compiled for R10.5.  Maybe this bug got fixed between R10 and R10.5?  I'll brb 😉
                  EDIT: D'oh! if anything, the problem is slightly worse in R11 (compiled with R11 SDK and run in R11).
                  • H Offline
                    Helper
                    On 04/12/2008 at 02:37, xxxxxxxx wrote:
                    Finally, in case anyone is trying to reproduce my results, here's my updated code snippet...
                        DescID idPosX = DescID(DescLevel(ID_BASEOBJECT_POSITION,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0));
                        DescID idPosY = DescID(DescLevel(ID_BASEOBJECT_POSITION,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0));
                        DescID idPosZ = DescID(DescLevel(ID_BASEOBJECT_POSITION,DTYPE_VECTOR,0),DescLevel(VECTOR_Z,DTYPE_REAL,0));
                        DescID idRotX = DescID(DescLevel(ID_BASEOBJECT_ROTATION,DTYPE_VECTOR,0),DescLevel(VECTOR_X,DTYPE_REAL,0));
                        DescID idRotY = DescID(DescLevel(ID_BASEOBJECT_ROTATION,DTYPE_VECTOR,0),DescLevel(VECTOR_Y,DTYPE_REAL,0));
                        DescID idRotZ = DescID(DescLevel(ID_BASEOBJECT_ROTATION,DTYPE_VECTOR,0),DescLevel(VECTOR_Z,DTYPE_REAL,0));
                        Matrix am;
                        DWORD totalkeys = 0;
                        BaseContainer stat;
                        LLONG inuse1, inuse2, memdiff, maxmem = 0;
                        LLONG tmemavg, tmemcnt = 0, tmemtotal = 0;
                        LLONG rmemavg, rmemcnt = 0, rmemtotal = 0;
                        //---------...S N I P...-----------------------------------------------
                            stime = BaseTime(pKey->time, m_animationFps);
                            GeGetMemoryStat(stat); // check memeory usage
                            inuse1 = stat.GetLLong(C4D_MEMORY_STAT_MEMORY_INUSE);
                            m_pBaseDoc->RecordKey(pJointObj, stime, idPosX, NULL, false, false, false);
                            m_pBaseDoc->RecordKey(pJointObj, stime, idPosY, NULL, false, false, false);
                            m_pBaseDoc->RecordKey(pJointObj, stime, idPosZ, NULL, false, false, false);
                            inuse2 = stat.GetLLong(C4D_MEMORY_STAT_MEMORY_INUSE);
                            memdiff = inuse2 - inuse1;
                            if( memdiff > maxmem )
                                maxmem = memdiff; // update max allocation tracking
                            tmemtotal += memdiff; // update total memory used for trans keys and count
                            tmemcnt +=3;          // used to compute average-memory-per-trans-key later
                            totalkeys += 3;
                            break;
                    ...the above also shows where and how my memory tracking was done (again, there's a similar block of code for the rotation keys, with separate tracking variables).
                    • H Offline
                      Helper
                      On 04/12/2008 at 09:34, xxxxxxxx wrote:
                      In my case, I would just create the track and keys the more low-level way ala: Ctrack::Alloc() and CCurve->AddKey(). It's more work (adding, adding undos, and setting values) but maybe this would reduce the memory consumption you are experiencing with RecordKey().
                      The consumptive results of RecordKey() could be something to do with undos. Maybe a test here would be to reduce your Undo Level setting drastically and see if there is any change in memory consumption overall.
                      • H Offline
                        Helper
                        On 04/12/2008 at 09:48, xxxxxxxx wrote:
                        Yeah, I've been suspecting that RecordKey() is doing some sort of AddUndo() internally, based on the symptoms.  Where can I change the Undo Level setting?  nm.. I found it in preferences... testing now...
                        • H Offline
                          Helper
                          On 04/12/2008 at 10:08, xxxxxxxx wrote:
                          Well, changing the Undo Depth doesn't seem to help, but I'll start looking into the lower level methods - thanks.
                          • H Offline
                            Helper
                            On 04/12/2008 at 10:10, xxxxxxxx wrote:
                            Automatic undos in the SDK can be either a blessing or a curse. I've no experience with RecordKey() so am unfamiliar with its behavior. It may be storing a full change undo (UNDO_CHANGE) which always includes the object, its children, and it branches (including tags, materials, animation) which can eat memory for breakfast as I was forced to deal with unavoidably. 🙂
                            • H Offline
                              Helper
                              On 04/12/2008 at 10:32, xxxxxxxx wrote:
                              Hmm... just to clarify...
                              Say I have 50 joints, with 6 tracks each (posx, posy, posz, rotx, roty, rotz). So that's 300 total tracks.  To add a new key, I would then:
                              • look up or otherwise retrieve my ptr to the CTrack (if I ultimately don't need CTrack pointers, I might just stash the CCurve pointers to start with)
                              • get the CCurve from the CTrack ( pCurve = pTrack->GetCurve() )
                              • either:
                                • Allocate a CKey ( pKey = CKey::Alloc() ), fill it in and pCurve->InsertKey(pKey) it.
                                • or:   pKey = pCurve->AddKey( time )  then just fill the key in ( pCurve->SetKeyDefault() + pKey->SetValue() )
                              ...is that all?  What's this undo stuff you're talking about?  In this case, I'm creating a new document, with enirely new data / keys.  Is there any need for me to create undos?
                              • H Offline
                                Helper
                                On 04/12/2008 at 11:10, xxxxxxxx wrote:
                                Bingo!  Well, I need to figure out/fix the rotation values again (as soon as I finish my happy-dance), but I went from 277MB being used down to 3MB by just doing the CCurve/CKey thing (it's a lot faster as well).
                                • H Offline
                                  Helper
                                  On 04/12/2008 at 11:15, xxxxxxxx wrote:
                                  When you create the new CTrack and CKeys, you could be adding undos (UNDO_NEW) - but it depends. In my case (IPP), the content could be being added to an existing document in which the user wants to be able to undo the addition. But if you are always creating a new document, the undos for these is probably unnecessary as there is nothing to 'undo' in a newly created document. 🙂
                                  I should add, if you aren't doing this already, after filling in your document, do doc->SetChanged() so that it is marked as unsaved (you only need to do this if you don't add undos).
                                  • H Offline
                                    Helper
                                    On 04/12/2008 at 11:24, xxxxxxxx wrote:
                                    ...and I went from _not being able to load the full animation_ to 33MB for the entire ~190,000 keys - yay.
                                    It looks like I just need to fix some gimble-lock issue with the rotations now.  Once I get it working, I'll post the updated code.
                                    • H Offline
                                      Helper
                                      On 04/12/2008 at 12:18, xxxxxxxx wrote:
                                      After taking time out for another happy-dance, here's the final working code (this time I'll post the rotation key section instead of the position key section.. and have removed all the memory tracking stuff for clarity) :
                                          //---------...S N I P...--- some variables setup earlier -----------------
                                          Matrix am;
                                          CKey *pCKey;
                                          LONG keyNdx;
                                          Vector hpbBase = MatrixToHPB(pJ->ml);  // 'rest' position, per joint
                                          BaseTime stime = BaseTime(i, m_animationFps);
                                          if( (DWORD)(pMyKey->time) == i ) // pMyKey is not a CKey, it's a different structure where my data is stored
                                              Vector hpb = MatrixToHPB(am);        // get HPB angles from joint-local animation matrix
                                              hpb = GetOptimalAngle(hpbBase, hpb); // correct for gimble-lock
                                              pCKey= pJ->pCurves[3]->AddKey(stime, &keyNdx); // RotX key
                                              if( pCKey) { pJ->pCurves[3]->SetKeyDefault(m_pBaseDoc, keyNdx); pCKey->SetValue(pJ->pCurves[3], hpb.x); }
                                              pCKey= pJ->pCurves[4]->AddKey(stime, &keyNdx); // RotY key
                                              if( pCKey) { pJ->pCurves[4]->SetKeyDefault(m_pBaseDoc, keyNdx); pCKey->SetValue(pJ->pCurves[4], hpb.y); }
                                              pCKey= pJ->pCurves[5]->AddKey(stime, &keyNdx); // RotZ key
                                              if( pCKey) { pJ->pCurves[5]->SetKeyDefault(m_pBaseDoc, keyNdx); pCKey->SetValue(pJ->pCurves[5], hpb.z); }
                                              break;
                                      ...the position-key code is basically the same, but just uses am.off.x/y/z values.  Also, I just cached the CCurve pointers as an array in my joint structure (0,1,2 are the position curve pointers).
                                      As a final comment for the curious, each key generated now uses ~200 bytes :).
                                      • H Offline
                                        Helper
                                        On 08/12/2008 at 02:02, xxxxxxxx wrote:
                                        I gather you resolved your problem then?
                                        cheers,
                                        Matthias
                                        • H Offline
                                          Helper
                                          On 08/12/2008 at 02:21, xxxxxxxx wrote:
                                          Yes - thanks.  It's apparently not a good idea to use RecordKey() :).
                                          I could sure use some help with CAWeight Tags now though: https://developers.maxon.net/forum/topic/4233
