    MatrixToRotAxis() != RotAxisToMatrix()
    4 Posts 0 Posters 762 Views
    • H Offline
      Helper
      On 25/11/2008 at 21:16, xxxxxxxx wrote:
      Cinema 4D Version:   R10+
      Platform:   Windows  ;
      I'm trying to convert some local matrices (of null/bone/joint objects) into Angle/Axis pairs, but I'm having a problem of those Axis/Angle pairs not reproducing the original matrix...
          // --------- S N I P ---------
          Matrix ml1 = op->GetMln();
          Vector pos = ml1.off;
          Real angle;
          Vector axis;
          MatrixDump(ml1, "Before"); // (debug print of matrix)
          // Convert Euler matrix to angle/axis
          MatrixToRotAxis(ml1,&axis,&angle);
          // re-create matrix, using angle/axis
          Matrix ml2 = RotAxisToMatrix(axis, angle);
          ml2.off = ml1.off;
          MatrixDump(ml2, "After"); // (debug print of matrix)
      ...ml2 only ends up the same as ml1 if ml1 was an Identity Matrix.  Should I expect the above to reproduce the original Matrix? Or is it expected that the various matrix values get transposed in the new Matrix?
      As far as I can tell from some other code, the RotAxisToMatrix() part is working as expected, so the problem is happening with MatrixToRotAxis() , but I'm willing to listen to any help in accomplishing the desired results.
      Thanks,
      Keith
      • H Offline
        Helper
        On 25/11/2008 at 21:35, xxxxxxxx wrote:
        Here's some helper routines in case you don't have something like this:
            #include <stdarg.h>
            #include <stdio.h>
            // GePrintF()
            void GePrintF(const CHAR *format,...)
            va_list arp;
            CHAR buf[1024];
            va_start(arp,format);
            vsprintf(buf,format,arp);
            GePrint(buf);
            va_end(arp);
            // MatrixDump()
            void MatrixDump(Matrix mx, char *name)
            GePrintF("======%s=======", name);
            GePrint("off.x = " + RealToString(mx.off.x) + " off.y = " + RealToString(mx.off.y) + " off.z = " + RealToString(mx.off.z) );
            GePrint("v1.x = " + RealToString(mx.v1.x) + " v1.y = " + RealToString(mx.v1.y) + " v1.z = " + RealToString(mx.v1.z) );
            GePrint("v2.x = " + RealToString(mx.v2.x) + " v2.y = " + RealToString(mx.v2.y) + " v2.z = " + RealToString(mx.v2.z) );
            GePrint("v3.x = " + RealToString(mx.v3.x) + " v3.y = " + RealToString(mx.v3.y) + " v3.z = " + RealToString(mx.v3.z) );
        • H Offline
          Helper
          On 25/11/2008 at 21:48, xxxxxxxx wrote:
          Here's the transposing I was referring to...
          • H Offline
            Helper
            On 25/11/2008 at 23:34, xxxxxxxx wrote:
            Erm... it looks like I stumbled across the answer...
            Here's the original MatrixToRotAxis() code from c4d_tools.cpp ...
                void MatrixToRotAxis(const Matrix &mm, Vector *v, Real *w)
                    Matrix m = mm;
                    // MatrixVectoren MUESSEN normiert sein!!!
                    m.v1=!m.v1;
                    m.v2=!m.v2;
                    m.v3=!m.v3;
                    // Winkel berechnen
                    *w = ACos((m.v1.x+m.v2.y+m.v3.z-1.0)/2.0);
                    // Achse berechnen
                    v->x= m.v2.z-m.v3.y;
                    v->y= m.v3.x-m.v1.z;
                    v->z= m.v1.y-m.v2.x;
                    *v = !(*v);
                    if (*v==0.0)
                        *v = Vector(0.0,1.0,0.0);
                        *w = 0.0;
            ...switching (reversing) the order of subtraction when building the axis Vector fixes my problem...
                void MyMatrixToRotAxis(const Matrix &mm, Vector *v, Real *w)
                    Matrix m = mm;
                    m.v1=!m.v1;
                    m.v2=!m.v2;
                    m.v3=!m.v3;
                    // Winkel berechnen
                    // NOTE: subtraction order reversed
                    // v->x= m.v2.z-m.v3.y;
                    // v->y= m.v3.x-m.v1.z;
                    // v->z= m.v1.y-m.v2.x;
                    v->x= m.v3.y-m.v2.z;
                    v->y= m.v1.z-m.v3.x;
                    v->z= m.v2.x-m.v1.y;
                    *v = !(*v);
                    if (*v==0.0)
                        *w = 0.0;
            ...I can now use RotAxisToMatrix() on the Angle/Axis generated by MyMatrixToRotAxis() to re-create the original Matrix.
            Would that count as a 'bug' in the original?
            Keith
