    update renderview while plugin is running
    6 Posts 0 Posters 751 Views
    • H Offline
      Helper
      On 16/10/2008 at 07:32, xxxxxxxx wrote:
      Cinema 4D Version:   11
      Platform:
      Hi!
      My Plugin parses big textfiles and sets alot of keys, while it's doing that I already want to see the Animation.
      Is that possible? If so, how? 🙂
      Greetings+thanks!
      • H Offline
        Helper
        On 16/10/2008 at 08:50, xxxxxxxx wrote:
        Render or Editor? For animation there are only three choices: play editor, preview render (e.g.: QuickTime), full render. You won't get either of the last two to render in anything near real-time.
        So, if you just want to see the animation as you go in the Editor, use AnimateDocument() to set the frame:
        LONG fps = baseDocument->GetFps();
        // In your loop or such
        BaseTime time = BaseTime::BaseTime(frame, fps);
        baseDocument->SetTime(time);
        baseDocument->AnimateDocument(NULL, TRUE, TRUE);
        EventAdd();
        To do the render, you'd have to render each frame individually setting the RenderData settings as you go. Note that there are differences between R11 and earlier versions.
        • H Offline
          Helper
          On 16/10/2008 at 23:34, xxxxxxxx wrote:
          Sorry, my bad, I meant the Editor.
          I was testing with the same solution, but unfortunately the editor didnt update. Even with EventAdd(EVENT_FORCEREDRAW).
          Is the problem that the plugin is still running? It updates the statusbar and its text just fine.
          Paul
          • H Offline
            Helper
            On 17/10/2008 at 00:56, xxxxxxxx wrote:
            As Im using AnimateDocument throughout my plugin to get updated values from objects, I tested to use EventAdd() there too, but it doesnt update the editor (but I get the correct values from objects at that time)
            • H Offline
              Helper
              On 17/10/2008 at 11:12, xxxxxxxx wrote:
              In that case, it may be that you need to run in a separate thread.
              Are you using a modal or non-modal dialog? Are you calling StopAllThreads() beforehand?
              Try GeSyncMessage(EVMSG_TIMECHANGED) to get the view to update. And EventAdd(EVENT_ANIMATE) to update everything else (AM et al).
              • H Offline
                Helper
                On 17/10/2008 at 11:45, xxxxxxxx wrote:
                You have to call DrawViews(), see this thread:
                refreshing the viewport
                cheers,
                Matthias
