    Setting Layer Browser
    6 Posts 0 Posters 869 Views
    • H Offline
      Helper
      On 24/10/2007 at 22:12, xxxxxxxx wrote:
      Cinema 4D Version:   10.111
      Platform:
      I'm running into a strange problem. Hopefully somebody here knows what's wrong.
      I'm trying to set some states of the layer browser. That's all fine, except when I'm trying to un-solo a layer. When I un-solo a layer, all the objects disappear from the Object Manager and viewports. They'll come back if I toggle any of the layer buttons.
      Here's the code I'm using:
      GeListHead* llist = bDoc->GetLayerObjectRoot();
      GeListNode* layer = llist->GetFirst();
      LayerObject* lObj = SearchLayers(layer, bDoc, layerName); //my own function to search for a specific layer
      const LayerData* pLData = lObj->GetLayerData(bDoc, TRUE);
      LayerData lData = *pLData;
      lData.solo = StringToBool(value); //value is coming from somewhere else
      lObj->SetLayerData(bDoc, lData);
      //I'm trying all of these to update the the scene
      lObj->Message(MSG_UPDATE);
      EventAdd(EVENT_FORCEREDRAW);
      DrawViews(DA_FORCEFULLREDRAW, NULL);
      EventAdd();
      Any ideas?
      • H Offline
        Helper
        On 27/10/2007 at 16:44, xxxxxxxx wrote:
        Please, any help at all?
        The layer button states change, so it looks like the right info is being sent to the layer object. Looks like some kind of core message is not being sent correctly.
        I tried adding bDoc->SetChanged(); but that didn't help, either.
        • H Offline
          Helper
          On 30/10/2007 at 03:37, xxxxxxxx wrote:
          I can confirm this. No idea why this happens. I asked the developers for help.
          cheers,
          Matthias
          • H Offline
            Helper
            On 30/10/2007 at 08:16, xxxxxxxx wrote:
            Thank you for the help, Matthias. I'm looking forward to hearing back from the developers. Hopefully, there's a workaround or an easy solution.
            • H Offline
              Helper
              On 02/11/2007 at 03:04, xxxxxxxx wrote:
              Additionally to changing the LayerData you also have to delete the document's Solo bit. Please check the attached source code. It un-solos the first layer.
              > _
              > Bool MenuTest::Execute(BaseDocument *doc)
              >      GeListHead *list = NULL;
              >      list = doc->GetLayerObjectRoot();
              >      if(!list) return FALSE;
              >      LayerObject *layer = NULL;
              >      layer = (LayerObject* )list->GetFirst();
              >      if(!layer) return TRUE;
              >      const LayerData *data = layer->GetLayerData(doc,TRUE);
              >      LayerData newdata(*data);
              >      newdata.solo = FALSE;
              >      doc->StartUndo();
              >      doc->AddUndo(UNDO_CHANGE,layer);
              >      layer->SetLayerData(doc, newdata);
              >      //delete the Solo bit
              >      doc->AddUndo(UNDO_BITS,doc);
              >      doc->ChangeNBit(NBIT_SOLO_LAYER, NBIT_DEL);
              >      doc->EndUndo();
              >      EventAdd();
              >      return TRUE;
              > _
              cheers,
              Matthias
              • H Offline
                Helper
                On 04/11/2007 at 12:32, xxxxxxxx wrote:
                Excellent! Thank you! If possible, I think it would be a good idea to make a note of that on the layer data page for the next SDK release.
