    Problem: tag->GetMaterial()->GetName();
    5 Posts 0 Posters 697 Views
    • H Offline
      Helper
      On 16/01/2007 at 01:38, xxxxxxxx wrote:
      Cinema 4D Version:   9.6
      Platform:   Windows  ;
      Hi, All!
      I the beginner in programming on C.O.F.F.E.E. I have faced a problem.
      I need to choose the first object to which the concrete material is appropriated.
      In COFFEE SDK:
         1. texture tag have a fuction GetMaterial();
         2. material have a function GetName();
      Why next code don't work:
          main(doc,op)
          var tag0=op->GetFirstTag();
           if (!tag0) {println("No Tags!"); return FALSE;}
           while (tag0->GetType()!= TAG_TEXTURE)
             tag0=tag0->GetNext();
             if (!tag0) return FALSE;
         var MatName=tag0->GetMaterial()->GetName();
         println(MatName);
      In result: Member not found
      • H Offline
        Helper
        On 16/01/2007 at 04:00, xxxxxxxx wrote:
        ãûûûû
        ñìàðè
        > >>[Marker] GetMaterial();
        >>>Returns the marker of the current material.r
        òîåñòü òà ôóíêöèÿ âîçâðàùàåò íå ìàòåðèàë, à êàêîéòî ñöóêî ìàðêåð. Äàëåå ââîäèøü â ïîèñêå ïî õåëïó ñëîâî marker, íàõîäèøü òàêóþ ôóíêöèþ
        [BaseMaterial] FindMaterial([Marker ,string] m);
        Íó è ñîîòâåòñòâåííî êîä:
               if (!tag0)
             return FALSE;
        var MatMark=tag0->GetMaterial();
        var doc = GetActiveDocument() ;
        var mat=doc->FindMaterial(MatMark);
        var matName = mat->GetName();
        println(matName);
        • H Offline
          Helper
          On 16/01/2007 at 04:07, xxxxxxxx wrote:
          Excuse me for russian. This guy understand me.
          And I think it is clear without words.
          • H Offline
            Helper
            On 16/01/2007 at 04:20, xxxxxxxx wrote:
            You get the name of the material like this:
            tag0#TEXTURETAG_MATERIAL->GetName()
            With #TEXTURETAG_MATERIAL you get the material attached to the texture tag.
            cheers,
            Matthias
            • H Offline
              Helper
              On 16/01/2007 at 13:19, xxxxxxxx wrote:
              Matthias, many thanks! All has turned out!
