    Custom GUI example?
    4 Posts 0 Posters 999 Views
    • H Offline
      Helper
      On 20/07/2005 at 17:54, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      "Are there any complete custom gui examples available that use user areas?
      Thank you,
      Damon Gilbert"
      • H Offline
        Helper
        On 21/07/2005 at 11:21, xxxxxxxx wrote:
        No, I don't think so. However, at some point in the existing examples you will have a dialog, and then you can insert a user area just like you do in a real dialog. Could you tell us a bit more of what you have already and what you want to do?
        • H Offline
          Helper
          On 23/07/2005 at 11:46, xxxxxxxx wrote:
          Greetings:
          Right now I have a user area working inside a asyncronous dialog. What I am trying to do is insert this user area into the attribute manager. This is only to manipulate date and not to store it.
          Hope you can help.
          Thanks
          Damon
          • H Offline
            Helper
            On 27/07/2005 at 06:54, xxxxxxxx wrote:
            Here is an example I found of a custom GUI for the string type.
                #include "c4d.h"
                const LONG MY_STRING_GUI_ID = 1016814;
                static LONG restypetable[] = { DA_STRING };
                class MyStringGUIDialog : public iCustomGui
                INSTANCEOF(MyStringGUIDialog, iCustomGui)
                private:
                  BaseContainer m_settings;
                  String m_str;
                  Bool m_tristate;
                public:
                  MyStringGUIDialog(const BaseContainer &settings, CUSTOMGUIPLUGIN *plugin)
                    : iCustomGui(settings, plugin), m_str("[default"), m_tristate(false), m_settings(settings) { }
                  virtual Bool CreateLayout (void)
                    GroupBegin(1002, BFH_SCALEFIT, 2, 1, "", 0);
                      AddStaticText(1001, BFH_FIT, 0, 0, "Test:", 0);
                      AddEditText(1000, BFH_SCALEFIT, 20, SizeChr(1));
                    GroupEnd();
                    return TRUE;
                  virtual Bool InitValues()
                    SetString(1000, m_str, m_tristate);
                    // We cannot look at the return value from SetString() since it's broken in 8.503
                    return TRUE;
                  virtual LONG Message(const BaseContainer& msg, BaseContainer& result)
                    switch(msg.GetId())
                    case BFM_DRAGRECEIVE:
                        if (msg.GetLong(BFM_DRAG_FINISHED) && CheckDropArea(1000, msg, TRUE, TRUE))
                          LONG type = 0;
                          void *object = NULL;
                          GetDragObject(msg, &type, &object);
                          if (object && type == DRAGTYPE_ATOMARRAY) // DRAGTYPE_OBJECT
                            AtomArray* array = static_cast<AtomArray*>(object);
                            Atom* atom = array->GetPreferred();
                            if (atom && atom->IsInstanceOf(Obase))
                              BaseObject* obj = static_cast<BaseObject*>(atom);
                              SetString(1000, obj->GetName());
                              BaseContainer actionmsg(BFM_ACTION), actionresult;
                              actionmsg.SetLong(BFM_ACTION_ID, 1000);
                              SUPER::Message(actionmsg, actionresult);
                        else SetDragDestination(CheckDropArea(1000, msg, TRUE, TRUE) ? MOUSE_POINT_HAND : MOUSE_FORBIDDEN);
                      } return TRUE;
                    return SUPER::Message(msg, result);
                  virtual Bool Command(LONG id, const BaseContainer& msg)
                    switch (id)
                    case 1000:
                        BaseContainer m(msg);
                        m.SetLong(BFM_ACTION_ID, GetId());
                        m.RemoveData(BFM_ACTION_VALUE);
                        m.SetData(BFM_ACTION_VALUE, GetData().GetValue());
                        SendParentMessage(m);
                        break;
                    return TRUE;
                  virtual Bool SetData(const TriState<GeData> &tristate)
                    m_str = tristate.GetValue().GetString();
                    m_tristate = tristate.GetTri();
                    return InitValues();
                  virtual TriState<GeData> GetData()
                    GetString(1000, m_str);
                    return m_str;
                class MyStringGUI : public CustomGuiData
                public:
                  virtual LONG GetId() { return MY_STRING_GUI_ID; }
                  virtual CDialog* Alloc(const BaseContainer &settings)
                    MyStringGUIDialog* dlg = gNew MyStringGUIDialog(settings, GetPlugin());
                    if (!dlg) return NULL;
                    CDialog *cdlg = dlg->Get();
                    if (!cdlg) return NULL;
                    return cdlg;
                  virtual void Free(CDialog *dlg, void *userdata)
                    if (!dlg || !userdata) return;
                    MyStringGUIDialog *sub = static_cast<MyStringGUIDialog*>(userdata);
                    gDelete(sub);
                  virtual CHAR *GetResourceSym()
                    return "MY_STRING_GUI";
                  virtual LONG GetResourceDataType(LONG *&table)
                    table = restypetable;
                    return sizeof(restypetable)/sizeof(LONG);
                Bool RegisterStringGUI()
                  static BaseCustomGuiLib mylib;
                  ClearMem(&mylib,sizeof(mylib));
                  FillBaseCustomGui(mylib);
                  return InstallLibrary(MY_STRING_GUI_ID, &mylib, 1000, sizeof(mylib))
                         RegisterCustomGuiPlugin("My String GUI", 0*PLUGINFLAG_HIDE, gNew MyStringGUI);
