    freeing result of CurrentStatetoobject
    5 Posts 0 Posters 553 Views
    • H Offline
      Helper
      On 28/06/2005 at 05:40, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      Platform:   Windows  ;
      I have a comprehension question. before R9 when calling MCOMMAND_CURRENTSTATETOOBJECT of ModelingCommanData it returned a baseobject as result. Now it returns an AtomArray.
      Ok, I can get the baseobjects out of it, but what´s the procedure for freeing the result now? Should I free the AtomArray or do I need to free all objects the AtomArray holds? When freeing the AtomArray does it automatically free the objects it holds?
      Thank you
      • H Offline
        Helper
        On 28/06/2005 at 06:27, xxxxxxxx wrote:
        An easy test is to try and see what leaks you get 🙂 AFAIK, yes you should free the atom array and no the atom array does not free the objects, the atom array is just a list of pointers. HTH.
        • H Offline
          Helper
          On 28/06/2005 at 06:57, xxxxxxxx wrote:
          Hi Dave,
          🙂 I see (I thought I had leaks from this, but it seems another plugin brought up those). I found that the ModelingCommandData struct does free the AtomArray already on destruction. Doesn´t this make freeing the AtomArray obsolete? I don´t seem to get any leaks when not doing so (I only free the object that I use from the atom array), but I would like to be sure that I am on the safe side. 🙂
          Thank you!
          • H Offline
            Helper
            On 28/06/2005 at 09:43, xxxxxxxx wrote:
            So it does, never noticed the destructor in operatingsystem 🙂
            • H Offline
              Helper
              On 28/06/2005 at 09:47, xxxxxxxx wrote:
              🙂 thank you
