    Question about SceneHooks
    3 Posts 0 Posters 298 Views
    • H Offline
      Helper
      On 12/05/2005 at 03:07, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      Platform:   Windows  ;
      Hello again 😉
      this time i have a Question about SceneHooks. The SDK doc states the following about various SceneHook functions:
      Note: Make sure that you only use this function when the user is somehow working with your plugin, so that other plugins can also use this hook when it's their turn.
      What does this exactly mean ? Can i stop ( let's say ) the draw function from beeing called ?
      • H Offline
        Helper
        On 12/05/2005 at 08:45, xxxxxxxx wrote:
        I think it just means if the user is not using your plugin then it should just exit from the functions, afaik you can't stop them getting called but you can just do nothing in them 🙂
        • H Offline
          Helper
          On 13/05/2005 at 10:12, xxxxxxxx wrote:
          Ah that makes some sense.
          Thank you.
