    CustomData and GUI Messaging
    6 Posts 0 Posters 961 Views
      On 24/08/2004 at 15:30, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      I need to do something very similar to the BUTTOM custom gui. I need to retrieve from the parent of the parameter some bitmaps that the parent is responsible for making ( like the bitmap returned from Message for BUTTON ). How do I initiate the Message to the parent?
      Best Regards,
      darf
        On 28/08/2004 at 00:32, xxxxxxxx wrote:
        The bitmap button custom GUI (I assume that's what you mean) does it like this:
        1. When you set the data for the bitmap button with a BitmapButtonStruct, a pointer to the object is included.
        2. Then this object pointer is used to send a standard base list message, MSG_DESCRIPTION_GETBITMAP.
        It wouldn't be possible to do this without step 1 since a custom GUI isn't restricted to the attributes manager; it can just as well be used in a standalone dialog when there's no parent object.
        Here's a short review of the relevant code snippets:
            class iBitmapButtonCustomGui : public iBaseCustomGui
              pObj;
            Bool iBitmapButtonCustomGui::SetData(const TriState<GeData> &tristate)
              const BitmapButtonStruct *ll =
                static_cast<const BitmapButtonStruct*>(
                  tristate.GetValue().GetCustomDataType(CUSTOMDATATYPE_BITMAPBUTTON));
              if (ll)
                pObj=ll->op;
              InitValues();
            Bool iBitmapButtonCustomGui::InitValues(void)
              if (pObj)
                pObj->Message(MSG_DESCRIPTION_GETBITMAP,&rts);
            Bool iBitmapButtonCustomGui::Command(LONG id,const BaseContainer &msg)
              switch (id)
              case 1000:
                  BaseContainer m(msg);
                  m.SetLong(BFM_ACTION_ID,GetId());
                  SendParentMessage(m);
                  break;
              return iCustomGui::Command(id,msg);
            Bool HostObjectData::GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, LONG &flags)
              switch(id[0].id)
              case BITMAP_BUTTON_ID:
                  LONG dirty = 0;
                  BitmapButtonStruct bbs = BitmapButtonStruct(static_cast<PluginObject*>(node), id, dirty);
                  t_data = GeData(CUSTOMDATATYPE_BITMAPBUTTON,bbs);
                  flags |= DESCFLAGS_PARAM_GET;
                  break;
              return ObjectData::GetDParameter(node, id, t_data, flags);
          On 29/08/2004 at 07:16, xxxxxxxx wrote:
          Thank you!
          Regards,
          darf
            On 29/08/2004 at 15:10, xxxxxxxx wrote:
            In the HostObjectData::GetDParameter you allocate a new custom data. Should we be freeing the one that was previously there or does C4D do that internally?
            Regards,
            darf
              On 29/08/2004 at 23:16, xxxxxxxx wrote:
              No, that is automatic. (In fact, since there's no non-automatic allocation, i.e. raw new/delete, in the above function, just temporaries and operator=, it's all just C++ memory management.)
                On 13/09/2004 at 12:02, xxxxxxxx wrote:
                f**king Brilliant.
                Happy.
                darf
