    KDZ Select & delete polys in SelectionTag
    3 Posts 0 Posters 406 Views
    • H Offline
      Helper
      On 23/07/2004 at 14:40, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      Platform:   Windows  ;
      Maybe I'm having a brainfart today, but I can't seem to figure out how to select the set of polygons pointed to by a SelectionTag and then delete them from the object. I'll keep plugging at it while awaiting a response.
      Thanks,
      Robert
      • H Offline
        Helper
        On 25/07/2004 at 22:56, xxxxxxxx wrote:
        You could probably do it by getting the actual selection, but here's a way that doesn't reinvent the wheel:
            PolygonObject* obj = static_cast<PolygonObject*>(
              doc->GetFirstObject());
            SelectionTag* tag = static_cast<SelectionTag*>(
              obj->GetTag(Tpolygonselection));
            #include "../../resource/res/description/Tpolygonselection.h"
            DescriptionCommand cmd;
            cmd.id = DescID(POLYGONSELECTIONTAG_COMMAND1);
            tag->Message(MSG_DESCRIPTION_COMMAND, &cmd);
            ModelingCommandData mcd;
            mcd.doc = doc;
            mcd.op = obj;
            mcd.mode = MODIFY_POLYGONSELECTION;
            mcd.flags = MODELINGCOMMANDFLAG_CREATEUNDO;
            SendModelingCommand(MCOMMAND_DELETE, mcd);
            EventAdd();
        • H Offline
          Helper
          On 26/07/2004 at 07:36, xxxxxxxx wrote:
          Ah ha! 🙂
          Got all the way up to using ModelingCommand, but could not figure how to actually delete the selection.
          Thanks, Mikael
          Robert
