    COF volumetric shader: refraction
    6 Posts 0 Posters 882 Views
    • H Offline
      Helper
      On 09/06/2003 at 22:41, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:    Mac  ;
      If I would like to implement refraction in an volumetric shader, do I have to calculate the refracted/reflected ray in the shader myself?
      Thanks & Cheers
      Kabe
      • H Offline
        Helper
        On 10/06/2003 at 22:24, xxxxxxxx wrote:
        Funny - I think this is related to another question I asked before (about tracegeometry) :
        var id,p,n;
        var ray = new(Ray);
        ray->p = vector(0.0);
        ray->v = vector(1.0,0.0,0.0); // ray travels from world origin along the X axis
        ray->pp0 = ray->pp1 = ray->pp2 = ray->p;
        ray->vv0 = ray->vv1 = ray->vv2 = ray->v; // fill mip variables
        ray->ior = 1.0; // refraction index for air
        id = TraceGeometry(ray,&p;,&n;,0);
        So you can define your own IOR for refraction - but TraceGeometry (defined in VolumeData) is wrong documentated - coffee says you need 5 variables and not only 4... happy guessing (at least in R7)...
        Well but the rayclass would implement the ior you have asked for. I guess that if you can access the ray that have "shot" you in the point, you can change its IOR and c4d would do the rest... but I am only guessing...
        cu
        • H Offline
          Helper
          On 11/06/2003 at 03:20, xxxxxxxx wrote:
          yes TraceGeometry is wrong documented. The missing paramter is a distance paramter that afai can see defines the maximum ray traveling distance.
          The TraceGeometry call should therefore i.e. look like this:
              vd->TraceGeometry(ray,100000000,min,&p,&n);
          Have fun both of you! Hope that helps...
          • H Offline
            Helper
            On 15/06/2003 at 09:24, xxxxxxxx wrote:
            Well, interesting sidenotes about TraceGeometry (Thanks, Samir!)
            However, I was thinking about something different:
            To implement refraction, can I jsut set Ray->IOR to the new value and Cinema takes care about calculating the ligh bending?
            Or do I have to manipulate the transmitting ray myself?
            Thanks for any insight!
            Kabe
            • H Offline
              Helper
              [PRE]vd->TraceGeometry(ray,100000000,min,&p;,&n;);[/PRE]
              It seems like it is still wrong documented even in the R13 C.O.F.F.E.E. SDK documentation!
              I hope it'll get fixed one day.
              • H Offline
                Helper
                On 27/10/2011 at 03:55, xxxxxxxx wrote:
                OK, I take note of this missing information in the C.O.F.F.E.E. docs.
