    Create a polyobject using C.O.F.F.E.E.
    2 Posts 0 Posters 404 Views
    • H Offline
      Helper
      On 10/05/2003 at 17:46, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Platform:
      Hello everybody.
      Could someone gifted please help me expand this codesnippet to show me how to add new points and polygons to an object?
      I have put a simple C.O.F.F.E.E tag on a null object.
      I got this code from peranders.com so a great thanx to him to begin with.
      main(doc,op)
      if (op->GetDown()) return FALSE;
      var childop=new(PolygonObject);
      childop- >InsertUnder(op); ****
      I have read the "Simple Poygon Problem" thread by Newbee but I didn't understand enough of it. I cannot find the alloc function talked about in that thread in the C.O.F.F.E.E. SDK.
      Regards / Feccand
      • H Offline
        Helper
        On 10/05/2003 at 18:47, xxxxxxxx wrote:
        Hi Feccand
        I'm also a coffee-newbie but may this code can help you:
        var newObject = new(PolygonObject);
        var variableChanged = new(VariableChanged);
        var backupTags = new(BackupTags);
        var totalpoints = 8; // change this value to you desired pointcount
        backupTags->Init(newObject);
        variableChanged->Init(0, totalpoints);
        if (!newObject->Message(MSG_POINTS_CHANGED, variableChanged))
             backupTags->Restore();
             return FALSE;
        var totalpolys = 6; // change this value to you desired polygoncount
        variableChanged->Init(0, totalpolys);
        if (!newObject->Message(MSG_POLYGONS_CHANGED, variableChanged))
             return FALSE;
        newObject->Message(MSG_UPDATE);
        doc->InsertObject(newObject, NULL, NULL);
        cya
