    • Unread
    using customgui listview
    Scheduled Pinned Locked Moved PYTHON Development
    3 Posts 0 Posters 2.1k Views
    • H Offline
      Helper
      On 23/02/2018 at 13:00, xxxxxxxx wrote:
      I'm new-ish to guis in python for c4d.  Looking for documentation.
      My goal is to implement a plugin with a list view in a dialog, similar to the texture manager (with the check/x buttons on each row).  I think I've successfully added a listview customgui, but can't find examples on how to interact with it.
      self.AddCustomGui(1001, c4d.CUSTOMGUI_LISTVIEW, "myList", c4d.BFH_SCALEFIT, 300, 200)
      Any guidance would be great.  I've checked both the python and cpp docs as sometimes you can find things in the latter to help with the former.  Might have just missed it completely, so apologies if I'm not being thorough enough.
      Thanks.
      Kevin
      • H Offline
        Helper
        On 26/02/2018 at 04:04, xxxxxxxx wrote:
        Hello KevinW,
        First of all, this is actually not possible to create a ListView in python. But you can create a TreeView, wich is basicly a more complexe ListView.
        So with that said, let's get's started !
        The bascis concept is to create a CUSTOMGUI_TREEVIEW, then attach an instance of a c4d.gui.TreeViewFunctions.
        Our instance of c4d.gui.TreeViewFunctions will then react to different functions according c4d.gui.TreeViewFunctions
        But let's go step by step
        First things is to create a GeDialog, and add a custom GUI. Ignore ListView() for the moment
        class TestDialog(c4d.gui.GeDialog) :
            _treegui = None # Our CustomGui TreeView
            _listView = ListView() # Our Instance of c4d.gui.TreeViewFunctions
            def CreateLayout(self) :
                # Create the TreeView GUI.
                customgui = c4d.BaseContainer()
                customgui.SetBool(c4d.TREEVIEW_BORDER, c4d.BORDER_THIN_IN)
                customgui.SetBool(c4d.TREEVIEW_HAS_HEADER, True) # True if the tree view may have a header line.
                customgui.SetBool(c4d.TREEVIEW_HIDE_LINES, False) # True if no lines should be drawn.
                customgui.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True) # True if the user can move the columns.
                customgui.SetBool(c4d.TREEVIEW_RESIZE_HEADER, True) # True if the column width can be changed by the user.
                customgui.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True) # True if all lines have the same height.
                customgui.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True) # Alternate background per line.
                customgui.SetBool(c4d.TREEVIEW_CURSORKEYS, True) # True if cursor keys should be processed.
                customgui.SetBool(c4d.TREEVIEW_NOENTERRENAME, False) # Suppresses the rename popup when the user presses enter.
                self._treegui = self.AddCustomGui( 1000, c4d.CUSTOMGUI_TREEVIEW, "", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 300, 300, customgui)
                if not self._treegui:
                    print "[ERROR]: Could not create TreeView"
                    return False
                self.AddButton(1001, c4d.BFH_CENTER, name="Add")
        Then we need to initializes some values to this CustomGui. So we implement InitValues within our GeDialog:
            def InitValues(self) :
                # Initialize the column layout for the TreeView.
                layout = c4d.BaseContainer()
                layout.SetLong(ID_CHECKBOX, c4d.LV_CHECKBOX)
                layout.SetLong(ID_NAME, c4d.LV_TREE)
                layout.SetLong(ID_OTHER, c4d.LV_USER)
                self._treegui.SetLayout(3, layout)
                # Set the header titles.
                self._treegui.SetHeaderText(ID_CHECKBOX, "Check")
                self._treegui.SetHeaderText(ID_NAME, "Name")
                self._treegui.SetHeaderText(ID_OTHER, "Other")
                self._treegui.Refresh()
                # Set TreeViewFunctions instance used by our CUSTOMGUI_TREEVIEW
                self._treegui.SetRoot(self._treegui, self._listView, None)
        Now that our GeDialog is created, we need to implement our ListView.
        The purpose of this class is to manage some objects (as the Object manager does for example).
        So we firstly need to create a custom Object which will represent an item in our list.
        class TextureObject(object) :
            Class which represent a texture, aka an Item in our list
            texturePath = "TexPath"
            otherData = "OtherData"
            _selected = False
            def __init__(self, texturePath) :
                self.texturePath = texturePath
                self.otherData += texturePath
            @property
            def IsSelected(self) :
                return self._selected
            def Select(self) :
                self._selected = True
            def Deselect(self) :
                self._selected = False
            def __repr__(self) :
                return str(self)
            def __str__(self) :
                return self.texturePath
        Note that in your case you may want to create an object from a BaseList2D, by doing RegisterNodeData, and which will allow you to support Drag and drop. But that's maybe something we can see in a future post.
        Then let's start by implemeting our class derived from c4d.gui.TreeViewFunctions
        class ListView(c4d.gui.TreeViewFunctions) :
            def __init__(self) :
                self.listOfTexture = list() # Store all objects we need to display in this list
                # Add some defaults values
                t1 = TextureObject("T1")
                t2 = TextureObject("T2")
                t3 = TextureObject("T3")
                t4 = TextureObject("T4")
                self.listOfTexture.extend([t1, t2, t3, t4])
        The whole concept of TreeView is to override some functions. So make sure to read the documentation to know which functions to override according your need.
        So we will define some more general options for our TreeView:
            def IsResizeColAllowed(self, root, userdata, lColID) :
            def IsTristate(self, root, userdata) :
                return False
            def GetColumnWidth(self, root, userdata, obj, col, area) :
                return 80  # All have the same initial width
            def IsMoveColAllowed(self, root, userdata, lColID) :
                # The user is allowed to move all columns.
                # TREEVIEW_MOVE_COLUMN must be set in the container of AddCustomGui.
        Now, since everything is setup we have to tell which item is the first one. Then all our lists view will be process as you process the current ObjectManager (GetNext,GetDown).
        To do it we override c4d.gui.TreeViewFunctions.GetFirst
            def GetFirst(self, root, userdata) :
                Return the first element in the hierarchy, or None if there is no element.
                rValue = None if not self.listOfTexture else self.listOfTexture[0]
                return rValue
        Then we have to handle GetDown (for child object, since in our case it's a simple list, we return None).
        GetNext which is the Object after the current Object, and GetPred wich is the Object before current Object.
        We also have to override GetID in order to uniquely identify an object in our list.
            def GetDown(self, root, userdata, obj) :
                Return a child of a node, since we only want a list, we return None everytime
                return None
            def GetNext(self, root, userdata, obj) :
                Returns the next Object to display after arg:'obj'
                rValue = None
                currentObjIndex = self.listOfTexture.index(obj)
                nextIndex = currentObjIndex + 1
                if nextIndex < len(self.listOfTexture) :
                    rValue = self.listOfTexture[nextIndex]
                return rValue
            def GetPred(self, root, userdata, obj) :
                Returns the previous Object to display before arg:'obj'
                rValue = None
                predIndex = currentObjIndex - 1
                if 0 <= predIndex < len(self.listOfTexture) :
                    rValue = self.listOfTexture[predIndex]
                return rValue
            def GetId(self, root, userdata, obj) :
                Return a unique ID for the element in the TreeView.
                return hash(obj)
        In order to handle selection we have to override Select and IsSelected
            def Select(self, root, userdata, obj, mode) :
                Called when the user selects an element.
                if mode == c4d.SELECTION_NEW:
                    for tex in self.listOfTexture:
                        tex.Deselect()
                    obj.Select()
                elif mode == c4d.SELECTION_ADD:
                    obj.Select()
                elif mode == c4d.SELECTION_SUB:
                    obj.Deselect()
            def IsSelected(self, root, userdata, obj) :
                Returns: True if *obj* is selected, False if not.
                return obj.IsSelected
        As you may be aware, in our GeDialog::InitValues we define some columns with different flags (LV_CHECKBOX, LV_TREE and LV_USER). Each one get a different implementation.
        So let's start with LV_CHECKBOX wich stand for check box.
        In order to make it work we have to override SetCheck and IsChecked
        Note that I used the same variable for selection, so if you select an item it will also check them, and if you check an item it will select it.
            def SetCheck(self, root, userdata, obj, column, checked, msg) :
                Called when the user clicks on a checkbox for an object in a
                `c4d.LV_CHECKBOX` column.
                if checked:
                    obj.Select()
                    obj.Deselect()
            def IsChecked(self, root, userdata, obj, column) :
                Returns: (int) : Status of the checkbox in the specified *column* for *obj*.
                if obj.IsSelected:
                    return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                    return c4d.LV_CHECKBOX_ENABLED
        Then LV_TREE element will check for Object name by calling GetName
            def GetName(self, root, userdata, obj) :
                Returns the name to display for arg:'obj', only called for column of type LV_TREE
                return str(obj) # Or obj.texturePath
        And finally LV_USER allow us to do some drawing function, as you will do if you are in a GeUserArea. Use DrawCell to draw anything you want (in our case a text). Take a look at DrawInfo-Dict
            def DrawCell(self, root, userdata, obj, col, drawinfo, bgColor) :
                Draw into a Cell, only called for column of type LV_USER
                if col == ID_OTHER:
                    name = obj.otherData
                    geUserArea = drawinfo["frame"]
                    w = geUserArea.DrawGetTextWidth(name)
                    h = geUserArea.DrawGetFontHeight()
                    xpos = drawinfo["xpos"]
                    ypos = drawinfo["ypos"] + drawinfo["height"]
                    drawinfo["frame"].DrawText(name, xpos, ypos - h * 1.1) # *1.1 ugly trick to make it nicer
        Then few stuffs can be usefull, like to trigger some scripts when you double click by overriding DoubleClick
        And also manager Delete key by overriding DeletePressed
            def DoubleClick(self, root, userdata, obj, col, mouseinfo) :
                Called when the user double-clicks on an entry in the TreeView.
                Returns:
                  (bool) : True if the double-click was handled, False if the
                    default action should kick in. The default action will invoke
                    the rename procedure for the object, causing `SetName()` to be
                    called.
                c4d.gui.MessageDialog("You clicked on " + str(obj))
            def DeletePressed(self, root, userdata) :
                "Called when a delete event is received."
                for tex in reversed(self.listOfTexture) :
                    if tex.IsSelected:
                        self.listOfTexture.remove(tex)
        And that's it, for our ListView, it's pretty basic but when you understand the concept is very easy, just take a look at all functions available for TreeViewFunctions.
        Additionally you may want to trigger some changes from GeDialog to your list, then remember we Create a button in our CreateLayout, now let's create his interaction.
            def Command(self, id, msg) :
                # Click on button
                if id == 1001:
                    # Add data to our DataStructure (ListView)
                    newID = len(self._listView.listOfTexture) + 1
                    tex = TextureObject("T{}".format(newID))
                    self._listView.listOfTexture.append(tex)
                    # Refresh the TreeView
        And voila ! 🙂
        Here the full example:
        https://pastebin.com/hp9KpZjx
        I hope everything make sense and answers to your initial question.
        For the moment it's pretty basic, but I will see how I can improve it in order to also demonstrate how to support Drag and Drop.
        Finally you can find some usefull informations in C++:
        TreeView made simple - Part 1[URL-REMOVED]
        Treeview made simple – Part 2[URL-REMOVED]
        Maxime
        [URL-REMOVED] @maxon: This section contained a non-resolving link which has been removed.
        • H Offline
          Helper
          On 26/02/2018 at 06:16, xxxxxxxx wrote:
          This is super helpful Maxime, thank you very much!
          This more then answers all my questions, and really makes a lot things much more clear.  This is more involved then I expected, but makes sense with your explanations.  Thanks very much.  I imagine this would be very useful to others as well!
          Kevin
