    GeUserArea.DrawBitmap
    Scheduled Pinned Locked Moved PYTHON Development
    11 Posts 0 Posters 2.1k Views
    • H Offline
      Helper
      On 07/12/2017 at 12:06, xxxxxxxx wrote:
      Cinema 4D Version:   R19
      Platform:      Mac OSX  ;
      Language(s) :       PYTHON  ;
      there seems to be an issue with GeUserArea.DrawBitmap().
      Not only that  BMP_DiMIMAGE is listed twice in the docs, but also the attribute of the function "mode" ,except BMP_NORMAL, can´t be assigned.
      Especially BMP_ALLOWALPHA is really needed.
      cheers
      Martin
      • H Offline
        Helper
        On 08/12/2017 at 08:09, xxxxxxxx wrote:
        Hi Martin,
        instead of drawing into the GeUserArea directly, we recommend to do all drawing (especially with alpha channels) into a GeClipMap. And then in the end only use DrawBitmap() with BMP_NORMAL and BMP_ALLOWALPHA to draw the GeClipMap (or rather the BaseBitrmap retrieved from the GeClipMap) into the GeUserArea. In this way BMP_ALLOWALPHA works for me as expected.
        I borrowed some of Niklas' code from this thread:
        import c4d.gui     as gui
        import c4d.bitmaps as bitmaps
        class Area(gui.GeUserArea) :
            def __init__(self, w = 20, h = 20, r = 1, g = 1, b = 1) :
                self.bmp = bitmaps.GeClipMap()
                self.bmp.Init(w, h)
                self.bmp.BeginDraw()
                self.w   = w
                self.h   = h
                r = int(r * 255)
                g = int(g * 255)
                b = int(b * 255)
                for x in xrange(w) :
                    for y in xrange(h) :
                        a = (x * 4 / float(w))**(y / float(h))
                        try:
                            a = 1 / (x**2 / float(w)**2) * a
                        except:
                            a = 0
                        a = int(a * 255)
                        self.bmp.SetPixelRGBA(x, y, r, g, b, a)
                self.bmp.EndDraw()
            def DrawMsg(self, x1, y1, x2, y2, msg) :
                #self.DrawSetPen(c4d.Vector(0, 0, 0))  # changes bg color seen through alpha
                w, h = self.w, self.h
                self.DrawBitmap(self.bmp.GetBitmap(),
                    0, 0, w, h, 0, 0, w, h, c4d.BMP_NORMAL | c4d.BMP_ALLOWALPHA)
            def GetMinSize(self) :
                return self.w, self.h
        class Dialog(gui.GeDialog) :
            def __init__(self, area) :
                self.area = area
            def CreateLayout(self) :
                self.AddUserArea(1000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
                self.AttachUserArea(self.area, 1000)
        def main() :
            area = Area(200, 200, 1.0, 0.66, 0.24)
            dlg  = Dialog(area)
            dlg.Open(c4d.DLG_TYPE_MODAL)
        The double entry in the Python documentation will be fixed.
        For now, I have moved this thread into the Python sub-forum. If you still feel BMP_ALLOWALPHA is buggy, please provide us with some more detail.
        • H Offline
          Helper
          On 08/12/2017 at 11:39, xxxxxxxx wrote:
          Hi Andreas,
          I used GeClipMap() before, but no luck.
          Confident through Niklas example I investigated further and the error occurred because a negative value was set to ww and wh attribute of the function.
          In this special case BMP_NORMAL is valid, while the other modes are not, confusing...
          An abs() function or an exception raise would be nice in GeUserArea.DrawBitmap().
          thanks,
          Martin
          • H Offline
            Helper
            On 11/12/2017 at 01:08, xxxxxxxx wrote:
            Hi Andreas,
            thanks for your help,
            some additional notes and a working example:
            - drawing everything into one clipmap and at the end draw this clipmap to the userarea,
             seems to be the only working way of layering several alpha bitmaps on top of each other.
            - it is important to set to c4d.GE_CM_DRAWMODE_BLEND in GeClipMap.SetDrawMode(),
             otherwise the alpha channel is not being used.
            - it is important to overwrite GeUserArea.Sized() ,
             otherwise the clipmap won't show up
            If you feel like it´s ok, you can mark this thread as solved.
            from c4d import bitmaps
            OK = 1003
            SHOW = 1005
            USERAREA = 1004
            class Canvas(c4d.gui.GeUserArea) :
              def __init__(self) :
                  self.w = self.GetWidth()
                  self.h = self.GetHeight()
                  self.rectangle=[-1,-1,-1,-1]
                  self.drawMap = bitmaps.GeClipMap()
              #UserArea Functions
                  self.OffScreenOn()
                  #draw everything in one clip map
                  self.drawMap.BeginDraw()
                  #draw background
                  self.drawMap.SetColor(51, 51, 51)
                  self.drawMap.FillRect(x1, y1, x2, y2)
                  #ensure that there is an object to draw the icon from
                  obj=doc.GetFirstObject()
                  if not obj:
                      print "no item"
                      self.drawMap.SetColor(255,170, 24)
                      self.drawMap.TextAt(3,3,"Please, insert an object into the scene for testing!")
                      self.drawMap.EndDraw()
                      self.DrawBitmap(self.drawMap.GetBitmap(), 0, 0, self.GetWidth(), self.GetHeight(),
                                      c4d.BMP_NORMAL)
                  #draw text
                  self.drawMap.TextAt(3,3,str(50000000))
                  #draw a rectangle
                  self.drawMap.SetColor(100, 100, 100, 255)
                  self.drawMap.FillRect(150, 0, 250, 50)
                  #needs to be set to draw alpha maps--------------------#
                  self.drawMap.SetDrawMode(c4d.GE_CM_DRAWMODE_BLEND, 255)
                  #draw icon with alpha
                  objicon = obj.GetIcon()
                  bmp = objicon['bmp']
                  wbmp = objicon['w']
                  hbmp = objicon['h']
                  xbmp = objicon['x']
                  ybmp = objicon['y']
                  icon = bitmaps.BaseBitmap()
                  icon.Init(wbmp,hbmp,depth=24)
                  bmp.CopyPartTo(icon, xbmp, ybmp, wbmp, hbmp)
                  alphaicon =icon.GetInternalChannel()
                  iconclip = bitmaps.GeClipMap()
                  iconclip.InitWithBitmap(icon,alphaicon)
                  self.drawMap.Blit( 50,50, iconclip, 0, 0,  wbmp, hbmp, rop = c4d.GE_CM_BLIT_COL)
                  #draw drag
                  self.drawMap.SetColor(200, 200, 255, 100)
                  xdr,ydr,x2dr,y2dr = self.toolDragSortEx()
                  self.drawMap.FillRect(xdr,ydr,x2dr,y2dr)
                  self.drawMap.SetColor(255, 255, 255, 255)
                  self.drawMap.Rect(xdr,ydr,x2dr,y2dr)
                                      c4d.BMP_NORMAL)
              def Sized(self, w, h) :
                  self.w=w
                  self.h=h
                  #needs to be set---------------------------------------#
                  self.drawMap.Destroy()
                  self.drawMap.Init(self.w, self.h)
              def InputEvent(self, msg) :
                  dev = msg.GetLong(c4d.BFM_INPUT_DEVICE)
                  if dev == c4d.BFM_INPUT_MOUSE:
                      return self.HandleMouseEvents(msg)
                  return False
              def HandleMouseEvents(self, msg) :
                  #init values
                  mousex = msg.GetLong(c4d.BFM_INPUT_X)
                  mousey = msg.GetLong(c4d.BFM_INPUT_Y)
                  start_x = mx = mousex - self.Local2Global()['x']
                  start_y = my = mousey - self.Local2Global()['y']
                  #drag interaction
                  state = c4d.BaseContainer()
                  self.MouseDragStart(c4d.KEY_MLEFT,start_x, start_y, c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE| c4d.MOUSEDRAGFLAGS_NOMOVE )
                  while True:
                      result, dx, dy, channels = self.MouseDrag()
                      #end of Drag
                      if result == c4d.MOUSEDRAGRESULT_ESCAPE:
                          break
                      if not self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, state) :
                          print "mouse right etc"
                          break
                      if state[c4d.BFM_INPUT_VALUE] == 0:
                          #mouse release
                          self.rectangle = [-1,-1,-1,-1]
                          self.Redraw()
                          break
                      #not moving, continue
                      if dx == 0 and dy == 0:
                          continue
                      #draging
                      mx -= dx
                      my -= dy
                      #start drag with rectangle
                      self.rectangle = [start_x,start_y,mx,my]
                      self.Redraw()
              def toolDragSortEx(self) :
                  if self.rectangle[0]<self.rectangle[2]:
                      x1,x2 = self.rectangle[0],self.rectangle[2]
                      x1,x2 = self.rectangle[2],self.rectangle[0]
                  if self.rectangle[1]<self.rectangle[3]:
                      y1,y2 = self.rectangle[1],self.rectangle[3]
                      y1,y2 = self.rectangle[3],self.rectangle[1]
                  return x1,y1,x2,y2
            class AreaDialog(c4d.gui.GeDialog) :
              def __init__(self,userarea) :
                  self.userarea = userarea
                  self.SetTitle("USERAREATEST")
                  self.AddUserArea(USERAREA, c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT)
                  self.AttachUserArea(self.userarea, USERAREA)
                  self.AddButton(OK, c4d.BFH_LEFT, name="OK")
                  self.AddButton(SHOW, c4d.BFH_LEFT, name="Show bitmap")
              def Command(self, id, msg) :
                  if id==OK:
                      self.Close()
                  if id==SHOW:
                      bitmaps.ShowBitmap(self.userarea.drawMap.GetBitmap())
            def main() :
              userarea = Canvas()
              dialog = None
              dialog = AreaDialog(userarea)
              dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE, xpos=100, ypos=100, defaultw=350, defaulth=500)
            if __name__=='__main__':
            cheers,
            Martin
            • H Offline
              Helper
              On 11/12/2017 at 09:52, xxxxxxxx wrote:
              Hi Martin,
              thanks for your detailed final conclusion.
              Just a note on GeUserArea.Sized() : This function should actually always be implemented for a GeUserArea to properly react to resizing requests (well, if you have elements that need adaption like your bitmap for example).
              • H Offline
                Helper
                On 12/12/2017 at 04:33, xxxxxxxx wrote:
                Hi Andreas,
                thanks for the advice.
                A last aesthetical kind of question on this subject.
                How should this clipmap draw solution draw sharp alphas and typo into the userarea?
                The clipmap is always blown up to screen pixels after DrawBitmap .
                Is there any solution?
                cheers,
                Martin
                • H Offline
                  Helper
                  On 13/12/2017 at 10:16, xxxxxxxx wrote:
                  Hi Martin,
                  I'm not sure I understand. Are you saying the GeClipmap gets modified/scaled by DrawBitmap()?
                  Looking at your DrawBitmap() call in the code above, you are passing the same GeUserArea width and height into "both" parameters of DrawBitmap(), while actually the second width and height should be the size of your bitmap. Could that be part of the problem?
                  • H Offline
                    Helper
                    On 13/12/2017 at 12:42, xxxxxxxx wrote:
                    Hi Andreas,
                    the clipmap was initialized with the width and height of the userarea. That´s why it makes no difference if  I use .Getwidth() from the userarea or .GetBw() from the clipmap.
                    The example code shows the loss of quality/sharpness comparing drawing text with GeUserArea.DrawText and drawing text on the clipmap and afterwards draw the bitmap from the clipmap.
                    You can simply replace the following DrawMsg function in my code above, to give it a try.
                    Thanks in advance!
                    Martin
                          self.OffScreenOn()
                          #draw background
                          #draw text
                          self.drawMap.TextAt(3,10,"Motion-Tracker-Tracks können jetzt auch runde Suchmuster verwenden. ")
                          self.DrawBitmap(self.drawMap.GetBitmap(), 0, 0, self.w, self.h,
                                              0, 0, self.drawMap.GetBw(),self.drawMap.GetBh(),
                                              c4d.BMP_NORMAL)
                          #draw with usual textdraw
                          self.DrawSetTextCol(c4d.COLOR_TEXT_SELECTED_DARK,
                                                      c4d.COLOR_TRANS)
                          self.DrawText("Motion-Tracker-Tracks können jetzt auch runde Suchmuster verwenden.", 3, 30)
                    • H Offline
                      Helper
                      On 15/12/2017 at 02:53, xxxxxxxx wrote:
                      Hi Martin,
                      GeClipmap.TextAt() and GeUserArea.DrawText() doesn't give the same result because they use different means to draw text from different contexts.
                      GeClipmap.TextAt() draws into a bitmap whereas GeUserArea.DrawText() directly draws into the GUI.
                      (I answered as Andreas left for vacation.)
                      • H Offline
                        Helper
                        On 19/12/2017 at 01:06, xxxxxxxx wrote:
                        Hi Yannick,
                        I see, could you please confirm than that there is either a sup-pixel sampling in drawBitmap or a working alpha draw method missing while drawing several alphas over elements in the user area draw function?
                        I can´t reach the quality/result  I´m aiming for…
                        cheers martin
                        • H Offline
                          Helper
                          On 22/12/2017 at 06:41, xxxxxxxx wrote:
                          Hi Martin,
                          I'm afraid I can't disclose internal implementation details.
