    empty Ttexture container
    3 Posts 0 Posters 456 Views
    • H Offline
      Helper
      On 21/02/2003 at 03:45, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Platform:   Windows  ;
      i don't know what i am doing wrong. maybe it's just a misunderstanding of the cinema api or even c++ ...
      the i use the following code to try to get the contents of the Ttexture container but it's aways empty...
      TextureTag* Tag = static_cast<TextureTag*>(Object->GetTag (Ttexture, 0));
       if (Tag)
        ObjName = Tag->GetName ();
        ObjName.GetCString (string, 1024, St7bit);
        cprintf ("\ntag name: ");
        cprintf (string);
        BaseContainer* TagContainer = Tag->GetDataInstance ();
        cprintf ("\ncontainer id = %d", TagContainer->GetId ());
        dword i = 0;
        while (1)
         dword id = TagContainer->GetIndexId (i);
         if (id == NOTOK) break;
         cprintf ("\ni = %d   id = %d", i, id);
         i ++;
      thanks for helping out in advance
      • H Offline
        Helper
        On 22/02/2003 at 12:27, xxxxxxxx wrote:
        here's some code from my source that may help. I don't think it like static_cast.
        <CODE>
        TextureTag* theTextureTag;
             theTextureTag = ( TextureTag* )inNode->GetTag( Ttexture, 0 );
             if ( theTextureTag != NULL )
                  BaseMaterial* materialOfNode = theTextureTag->GetMaterial();
        </CODE>
        inNode is a BaseObject pointer
        • H Offline
          Helper
          On 22/02/2003 at 23:36, xxxxxxxx wrote:
          There are no situations in the C4D SDK where reinterpret_cast<> vs. static_cast<> makes any other difference than whether the compiler accepts the cast or not. (The former is almost like a standard C cast while the latter requires that the cast makes sense.)
          It looks like the texture tag doesn't store its data in the container. Then you have to ask for description parameters directly:
               BaseObject* Object = doc->GetFirstObject();
               if (Tag)
                String ObjName = Tag->GetName();
                GePrint("tag name: " + ObjName);
                AutoAlloc<Description> desc;
                Tag->GetDescription(desc, NULL);
                GePrint("description");
                void* b = desc->BrowseInit();
                const BaseContainer* bc = 0;
                DescID id, groupid;
                while (desc->GetNext(b, &bc, id, groupid))
                 GeData data;
                 Tag->GetParameter(id, data, NULL);
                 GePrint("id = " + DescIDToString(id) + "  data = " + GeDataToString(data));
                desc->BrowseFree(b);
          This code uses a few debug output function that I will paste at the bottom of this message. Of course, to just access a know value you could do:
               GeData matlink;
               tag->GetParameter(DescID(TEXTURETAG_MATERIAL), matlink, NULL);
               BaseMaterial* mat = static_cast<BaseMaterial*>(matlink.GetLink(doc, Mbase));
               GePrint(mat->GetName());
          Here are the debug functions:
              String VectorToString(Vector v);
              String DescIDToString(const DescID& id);
              String BCToString(const BaseContainer& bc);
              String GeDataToString(const GeData& data);
              String FourToString(LONG x);
              String LongFourToString(LONG x);
               return "[" + RealToString(v.x) + ","
                + RealToString(v.y) + ","
                + RealToString(v.z) + "]";
                String res;
                res += "{";
                for (int i = 0; i < id.GetDepth(); ++i)
                  res += "id: " + LongFourToString(id[i].id) + ", dt: " +
                    LongToString(id[i].dtype) + ", cr: " +
                    LongToString(id[i].creator) + ((i != id.GetDepth() - 1) ? "  -  " : "");
                res += "}";
                return res;
                switch(data.GetType())
                  case DA_NIL: return "DA_NIL";
                  case DA_LONG: return LongFourToString(data.GetLong());
                  case DA_REAL: return RealToString(data.GetReal());
                  case DA_TIME: return "T=" + RealToString(data.GetTime().Get()) + "s";
                  case DA_VECTOR: return VectorToString(data.GetVector());
                  case DA_MATRIX: return "DA_MATRIX";
                  case DA_BYTEARRAY: return "DA_BYTEARRAY";
                  case DA_STRING: return "\"" + data.GetString() + "\"";
                  case DA_FILENAME: return "$" + data.GetFilename().GetString() + "$";
                  case DA_CONTAINER:
                      BaseContainer* bc = data.GetContainer();
                      if (bc == NULL) return "bc==0";
                      return BCToString(*data.GetContainer());
                  case DA_ALIASLINK:
                      BaseLink* bl = data.GetBaseLink();
                      if (bl == NULL || bl->GetLink(GetActiveDocument()) == 0) return "link==0";
                      return bl->GetLink(GetActiveDocument())->GetName();
                  case DA_MARKER: return "DA_MARKER";
                return "Unknown";
                String res;
                res += "[" + LongFourToString(bc.GetId()) + "; ";
                GeData* data = 0;
                int i = 0;
                do
                  data = bc.GetIndexData(i);
                  if (!data) break;
                  res += LongFourToString(bc.GetIndexId(i)) + "=";
                  res += GeDataToString(*data);
                  res += ", ";
                  i += 1;
                while (i < 50);
                res += "]";
                return res;
               String res;
               CHAR s[4];
               CHAR* sx = reinterpret_cast<CHAR*>(&x);
               s[0] = sx[3];
               s[1] = sx[2];
               s[2] = sx[1];
               s[3] = sx[0];
               res.SetCString(&s[0], 4, St7bit);
               return res;
               return "{" + LongToString(x) + "," + FourToString(x) + "}";
