    Unicode 'c4d_string.str' troubles
    4 Posts 0 Posters 651 Views
      On 20/01/2005 at 12:59, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      I have UniPad. The file is saved as UTF-8 Unicode. The plugin fails to load (so no errors, no idea). I use GeLoadString() for all resource strings. Would this affect folder/file names stored in c4d_string.str and used for Filename classes, even if in English?
      Robert
        On 20/01/2005 at 14:50, xxxxxxxx wrote:
        Oh, I see. Don't tell anybody that it has to be ASCII+UCN with Byte Order Mark turned off, but keep insisting on UTF-8.
        Get it right, guys!!!
        Robert
          On 21/01/2005 at 09:51, xxxxxxxx wrote:
          That seems to be an error in the documentation, if by "insist" you mean the one reference on the Dialog layout page: "The string files are stored in Unicode UTF-8...". I'll change this for the R9 docs. Thanks for reporting!
            On 21/01/2005 at 10:57, xxxxxxxx wrote:
            It also shows up (at least in 8.0 docs) in String class, GetCStringLen() and SetCString(), and under StringEncoding. This is misleading since it isn't strict UTF-8, but ASCII+UCN, which is with what the non-English Resource strings are encoded.
            What is interesting is that the English strings appear to be UTF-8 encoded, but luckily for me (when the trouble arose), I had the full language pack installed on one of my C4D installs. With them, I was able to see the different encoding for them in UniPad.
            The ASCII+UCN encoding seems to work cross-platform (though this could be an artifact of MacOS 10.3.7 and C4D R9 and widening of compliances between the platforms).
            Thanks Mikael,
