    show/hide dialog items does not update
    7 Posts 0 Posters 630 Views
      On 10/01/2005 at 10:10, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      i have a dropdown item in my dialog.
      depending on the selection, different dialog items should be hidden or shown.
      it works fine, but the items are only shown/hidden, when i press another button or slider or anything like that.
      is there a possibility to update the property dialog ? direct after selecting something out of a dropdownmenue ?
      sorry for my bad english, but i hope you understand, what i need to know 🙂
      best regards
        On 10/01/2005 at 10:39, xxxxxxxx wrote:
        where are you modifying the elements? Is this is a "usual" dialog or are you talking about the Attributes Manager?
        In a dialog you need to rebuild the group the elements are in. There´s an example in the SDK if I remember right.
        For the AM, all you need to do is overloading GetDDescription and show/hide the elements in there. The AM will automatically update.
        Some code snippets would surely help.
          On 10/01/2005 at 11:23, xxxxxxxx wrote:
          hi samir,
          its the attribute manager.
          here is the part of showing and hiding:
          > if (stmode == 3)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(CARRIER_DISTANCE), ar);
          >  if (bc)
          >   bc->SetBool(DESC_HIDE, FALSE);
          >  bc = description->GetParameterI(DescLevel(CARRIER_WIDTH), ar);
          >  if (bc)
          > if (stmode == 2)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(CARRIER_WIDTH), ar);
          >  if (bc)
          > if (stmode == 1)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(BASE_THICKNESS), ar);
          >  if (bc)
          >   bc->SetBool(DESC_HIDE, TRUE);
          > if (stmode == 4)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(BASE_OUTSIDE_WIDTH), ar);
          >  if (bc)
          >  bc = description->GetParameterI(DescLevel(BASE_OUTSIDE_HEIGHT), ar);
          >  if (bc)
          >  if (mode == 1)
          >  //Second Level Group einblenden
          >  BaseContainer* bc = description->GetParameterI(DescLevel(ID_SECOND_LEVEL_GROUP), ar);
          >  if (bc)
          > if (mode == 2)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(ID_MULTIPLE_FLOOR_GROUP), ar);
          >  if (bc)
          >  if (dir == 0)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(SL_SPACE_GAP), ar);
          >  if (bc)
          >  if (advgap)
          >  BaseContainer* bc = description->GetParameterI(DescLevel(ID_MULTIPLE_FLOOR_ADV_GROUP), ar);
          >  if (bc)
          >  flags |= DESCFLAGS_DESC_LOADED;
          >  return ObjectData::GetDDescription(node, description, flags);
          as i can remember (i stopped developing 2003 and continue now) the dialog worked fine. now with 8.5 the dialog changes only, when i press a button or another item after i've choosen the type of elements i want to see from the dropdown....
          i hope, this hels a little bit...
          ralph
            On 10/01/2005 at 11:29, xxxxxxxx wrote:
            seems all to be correct.
            Where do you get the stmode/mode etc. variables from? Are you getting those values within GetDDescription()?
              On 10/01/2005 at 21:08, xxxxxxxx wrote:
              these variables are global at the moment, but they get their value in
              GetVirtualObjects() via "data->GetLong(QS_STMODE)"
              edit:
              i now put the "data->Get..." functions into "Message()" is that the right way ? it seems to work...
                On 11/01/2005 at 05:09, xxxxxxxx wrote:
                global values are no good idea for this as they might be filled at a later point in the pipeline. And most probably GetDDescription is called before GetVirtualObjects (as you seem to have noticed already).
                I would fill them directly in GetDDescription if not necessary otherwise (or make them a private member variable if not needed otherwise) but if it works in the message function... (depends on when you´d need it).
                  On 11/01/2005 at 05:20, xxxxxxxx wrote:
                  "global values are no good idea for this as they might be filled at a later point in the pipeline"
                  i know, that this should not be, it is a "artefakt" from the beginning, they were defined only for testing. after that i forget to put them into my class. it is not necessary, thart they are global. i'll fix this.
