    instanceof() clears BaseObject pointer
    2 Posts 0 Posters 282 Views
      On 04/01/2005 at 10:28, xxxxxxxx wrote:
      Cinema 4D Version:   9.012
      I've received a valid bug report for one of my COFFEE plugins that only occurs in R9.012 (no problems in earlier supported versions). Here is the code:
           var oc, op;
           if (!(op = GetActiveObject(doc))) return;
           // Process active Object
           // - Make editable if necessary
           if (!instanceof(op, PointObject))
                var bc = new(BaseContainer);
                doc->StartUndo();
                doc->AddUndo(UNDO_OBJECT_REC, op);
                SendModelingCommand(MCOMMAND_MAKEEDITABLE, doc, op, bc, MODIFY_ALL);
                doc->EndUndo();
                op = GetActiveObject(doc);
                undos = TRUE;
      // This line prints!
           if (!op) println("That ain't right!");
      And, yes, there is an active object in the first call. This could be related to SendModelingCommand()?
      Any work arounds for this - like an update to COFFEE, finally? 😉
      Robert
        On 04/01/2005 at 11:27, xxxxxxxx wrote:
        Worked it out. Definitely a difference in SendModelingCommand() causing the issue. The workaround is not to try to do it to a Nullobject grouped set in R9. What did you guys do in R9?! 😉
        Robert
