    Storage of data
    2 Posts 0 Posters 203 Views
      On 04/01/2005 at 10:24, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      i have problems storing persistent data (like member variables) in my from ObjectData derived class:
      class C4DNode_NodeData: public ObjectData
      INSTANCEOF(C4DNode_NodeData,ObjectData)
      private:
           String teststring;
           virtual Bool GetDDescription(GeListNode *node, Description *description,LONG &flags;);
           void SetString(String _g);
      //the following functions are in the same order in that they are called
      Bool C4DNode_NodeData::Init(GeListNode *node)
      {     teststring = "initvalue";
      void C4DNode_NodeData::SetString(String _g)
      {     teststring = "newvalue";
      Bool C4DNode_NodeData::GetDDescription(GeListNode *node, Description *description,LONG &flags;)
           GePrint(teststring); //here is teststring "initvalue", not "newvalue"
      I tried the same with a BaseContainer, but the function SetString() doesn't change the value. But if i change an existing container of my description in SetString() with ...->SetLong(TESTID, 1) the value is changed in my object. What's wrong? Is there a better way to store member variables?
      Thanks for any help,
      Torsten
        On 07/01/2005 at 02:56, xxxxxxxx wrote:
        Problem solved (in an unusual way).
        I change my member variables by sending a message.
        {     String gtemp = "newvalue";
             ((PluginObject* )this)->Message(UWM_MYOWNMESSAGE, &gtemp;);
        Bool C4DNode_NodeData::Message(GeListNode *node, LONG type, void *t_data)
             if(type == UWM_MYOWNMESSAGE)
             {     String* gtemp = (String* )t_data;
                  g = gtemp->SubStr(0,gtemp->GetLength()); //found no better way to get String from String*
        Torsten
