    CheckValueRanges()?
    2 Posts 0 Posters 231 Views
      On 02/01/2005 at 21:27, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Okay, strangeness.
      Here's my code, called from iPDialog::Command() :
      // CMD: Set FPS
      void iPDialog::SetFPS(LONG value)
           //if ((value < FPS_MIN) || (value > FPS_MAX))
           if (CheckValueRanges()) SetLong(IP_SET_FPS, settings.GetFPS(), FPS_MIN, FPS_MAX, 1);
           else settings.SetFPS(value);
      1. Note that checking for the opposite return works (TRUE = bad value, FALSE = good value). This is not what the documentation says. Maybe I'm not implementing it correctly - how should I know since there are no examples or explanations.
      2. When there is a bad value in this case, it doesn't set it to the previous value (settings.GetFPS()), it makes it a part of the value (501 > 50, 600 > 60, etc.).
      I could use my own check (commented out), but can't get the gadget to update and cannot find a proper method/message to do this. Appreciate some explanations.
      Robert
        On 03/01/2005 at 00:41, xxxxxxxx wrote:
        Figured it out:
        The value is always within bounds, so I just need to grab it and then set the EditNumber gadget to show the bounded value instead of the typed-in one.
        Robert
