    No Bones Found ?
    12 Posts 0 Posters 1.2k Views
      On 29/12/2004 at 08:06, xxxxxxxx wrote:
      I tried this one, but i dont work again 😞
        On 29/12/2004 at 08:13, xxxxxxxx wrote:
        try obj->GetType()==5123
          On 29/12/2004 at 09:56, xxxxxxxx wrote:
          All that you are doing is replacing the #define Obone with its numerical definition:
          #define Obone 5123
          If that makes a difference, something smells fishy in Shveeden. 🙂
            On 29/12/2004 at 10:01, xxxxxxxx wrote:
            Upps, I thought he was using COFFEE and that the definition might have changed. But as he is using C++ this is of course nonsense 🙂
            It should work then though. Have you checked the pointer if it´s valid? Cannot think of anything else.
              On 29/12/2004 at 10:49, xxxxxxxx wrote:
              Yes it is valid, otherwise i would get an exception 😞
                On 29/12/2004 at 11:15, xxxxxxxx wrote:
                That's alright Katachi. 🙂
                I'm going out on a limb and wondering if you are getting to all of the objects in your document. Have you checked that you are at least traversing all of the scene objects regardless of type?
                Robert
                  On 29/12/2004 at 11:22, xxxxxxxx wrote:
                  Yes im sure, he dont get the Bones, he find all other (Polygon, Nullobject etc) but Bones not 😞
                    On 29/12/2004 at 12:45, xxxxxxxx wrote:
                    So you are saying that if you do a full document object traversal, without worrying about object type, the bones still do not show up?
                    You are doing something like this:
                    // Print Document's object hierarcy
                    void PrintHierarchy()
                         BaseObject *obj = baseDoc->GetFirstObject();
                         for (obj = baseDoc->GetFirstObject(); obj; obj = obj->GetNext())
                              GePrint(obj->GetName());
                              PrintChildren(obj->GetDown(),1);
                    // Recursively print children
                    void PrintChildren(BaseObject *obj, UBYTE level)
                         String stext = "";
                         for (UBYTE i = 0; i < level; i++) stext = stext+" ";
                         for (; obj; obj = obj->GetNext())
                              GePrint(stext+obj->GetName());
                              PrintChildren(obj->GetDown(), level+1);
                    and none of the bone objects show up in the Console print out?
                    Robert
                      On 29/12/2004 at 13:23, xxxxxxxx wrote:
                      Oh now it shows, it must a bug in my routine 🙂 sorrys 🙂
                        On 29/12/2004 at 15:11, xxxxxxxx wrote:
                        No problem. It is always good to ask and get others' input. 🙂
