    Retrieving Object Data Problem
    3 Posts 0 Posters 358 Views
      On 28/12/2004 at 05:52, xxxxxxxx wrote:
      Cinema 4D Version:   9.012
      <CODE>objectsChunk *_FormatSave::getObjData(BaseObject *obj)
      Polygon *poly = (Polygon * ) obj->GetTagData(Tpolygon);
           Vector *point = (Vector * ) obj->GetTagData(Tpoint);
           LONG numPolygons = obj->GetTagDataCount(Tpolygon);
           LONG numVerts = obj->GetTagDataCount(Tpoint);
      block->verts = new Vector3[numVerts];
      for (i = 0; i < numVerts; i++) {
                block->verts _.x = point _.x;
                block->verts _.y = point _.y;
                block->verts _.z = point _.z;
      }</CODE>
      Is this correct? it's seems to be wrong because the "obj->GetTagDataCount(Tpoint)" and "obj->GetTagDataCount(Tpolygon)" are returning 0 values, in scenes that have a cube object (i'm completely c4d noob too, i got c4d just for coding).
      obs.: the "BaseObject" parameter of "objectsChunk *_FormatSave::getObjData(BaseObject *obj)" method is receiving data from the following call (modified for obvious reasons) :
      <CODE>getObjData( BaseDocumentInst->GetFirstObject() );</CODE>
      I started learning/coding c4d today and got some progress. I'm building this plugin to export/import my own data format and thus use it to load from my game engine.
      And one more thing, there is a easy way to debug my plugin project, like using printf()?
      Thanks in advance.
        On 28/12/2004 at 08:12, xxxxxxxx wrote:
        i made some mistakes
        block->verts.x = point.x;
        block->verts.y = point.y;
        block->verts.z = point.z;
        should be:
        block- >verts _.y = point _.y;
        block- >verts _.z = point _.z;
        and the language is C++
          On 28/12/2004 at 08:31, xxxxxxxx wrote:
          solved the problem
          i was using a Cube Object, not a Polygon Object (oh god \o/)
          and downloaded the Cinema 4D R8 SDK Help and discovered the GePrint() method from c4d_gerenal 🙂
