    Mix bitmaps in c.o.f.f.e.e.
    5 Posts 0 Posters 559 Views
      On 07/12/2004 at 07:29, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      Hi,,,,
      Is it possible to access a Layer shader in c.o.f.f.e.e.?
      I need to mix some bitmaps together , for a colour channel texture.....
      Any advice greatly appreciated....
       Cheers........
      lonetad.
        On 08/12/2004 at 01:08, xxxxxxxx wrote:
        I'm afraid it's not possible to access the new Layer shader in C.O.F.F.E.E.
          On 08/12/2004 at 04:24, xxxxxxxx wrote:
          OK,  thanks anyway.....
            On 11/11/2009 at 14:47, xxxxxxxx wrote:
            Is this still true in 2009? I'm trying to construct a material from scratch with C.O.F.F.E.E:
            The plugin generates a handful of vertex maps and I want to color the object with them automatically. My manual protocol works fine, now I just need to get the plugin to do the same thing.
            Done:
            Construct a new material
            Apply new material to specific object
            Generate vertex maps from provided data
            ToDo:
            Create a LayerShader in the CHANNEL_COLOR box
            In the Layer Shader:
               Create 3 new ColorShaders R, G, B
               Create 3 new VertexMapShaders
                  Set each VertexMapShader to LayerMask
                  Fill #SLA_DIRTY_VMAP_OBJECT with the appropriate VertexMap Tags from the object.
            Are any of these things on my ToDo list possible? So far, I can only put a texture path into the CH_TEXTURE box, not a layer, let alone access the layers other details.
            Graham
              On 17/11/2009 at 05:21, xxxxxxxx wrote:
              Access to the LayerShader is currently vey limited in C++ and not possible at all in COFFEE.
